1 Couple of electric questions Tue Mar 15, 2022 1:10 am
Zuomine
Hi all!
This is my first post on the forum, so please forgive me if the formatting is a bit wonky. English is also my second language, so some sentences may not be so clear.
I am currently building a cafe racer/scrambler 1987 BMW K100 RS. I'm rebuilding the bike at the moment, but I am having some trouble with my electrics. I have 3 questions/situations that I would like to get some help with:
1. Turn indicators
I have installed these LED turn indicators on my bike. I am having a similar problem as described on this post, the indicators only light up and a beeping sound is heard. No flashing at all. Do you think that my problems would be fixed by removing the ground on pin 7 of the U243B integrated circuit as described in the reply by robmack or should I start looking for the correct resistors for these indicators?
2. Tail/brake light
I have installed this LED brake/tail-light on the bike. I am having some issues with this. I have located the correct wires for brake/tail lights on the main wire harness of the bike and tried plugging them in accordingly (1 wire for the tail light, 1 for brake light and 1 ground). I have come across different situations with the light
So currently the situation is that whenever I plug in the brake light wire, the tail light stops working and only lights up when pressing the brake light switch. I have tested the light using a battery (plugging the tail light and the brake light wire directly to a battery), the light works fine. Any ideas regarding this? Do I need a resistor or do I need to modify the BMU somehow?
3. Speedometer Acewell 2853
I have installed my speedometer succesfully otherwise, but I am unsure about the placement of the yellow wire (speed). I am using the Marulabs BEP 3.0 lunchbox remover. Should I just plug the yellow wire in to the SPD-slot on the BEP box? The yellow wire is forked in to two, but I think I only need to plug in one wire to the box?
I will happily provide any extra information needed about these problems and I really appreciate anyone taking the time to read through my post.
Thank you for reading, looking forward to your insight!
Best,
Zuomine
1. Turn indicators
2. Tail/brake light
- All 3 wires plugged in - The tail light does not work, but if I press the brake light switch (turn on the brake light), the tail light lights up. This light that comes on is not the brake light, as I have seen that it is brighter. So in summary, tail light does not work but lights up when I press the switch.
- Only plugging in the brake light wire - The tail light does not work. The brake light lights up normally (brighter than in 1.) when pressing the switch.
- Only plugging in the tail light wire - The tail light works normally. The brake light does not work at all.
Best,
Zuomine
