1Back to top Go down   Does the Length Matter? Empty Does the Length Matter? Fri Mar 25, 2022 3:26 pm
tjh1985
tjh1985
  1. My custom '85 K100RS needs a new transmission.
  2. I purchased a 1993 K1100LT transmission w low miles to replace it with.
  3. Because the bike has a custom frontend the length of the OEM clutch cable (part #32732324960 - 1,625mm long) is far longer than I need and there is a lot of extra cable wrapped under the tank to keep it out of site, but I'm guessing this a poor solution.
  4. There is another OEM clutch cable (part #32732324955 - 1,510mm in length) which shortens things at least some.
  5. I would like to use the shorter one, but was informed that shorter cable only works with K1100RS transmission and specifically not the LT transmission I have. Is this true?
  6. Is there another clutch cable out there that I could use that I'm not aware of? (I have attempted to make a custom clutch cable which was a total fail)
As always - Thank you for all the help,
Thomas
http://www.thomashurst.com
2Back to top Go down   Does the Length Matter? Empty Re: Does the Length Matter? Fri Mar 25, 2022 3:41 pm
1: Dude.....
2: You lucky bastard Shocked
3: You're right......
4: https://www.realoem.com/bmw/en/partxref?id=0563-EUR-10-1987-K569-BMW-K_75_S_0563,0572_&diagId=32_1964&q=32732324955
5; Doesn't depend on the gearbox, because RS and LT are the same. It's the length needed for the high bar.
6: K75S, K100RS (2V and 4V) and K1100RS have the shortest OEM cables. They all fit your K.
Does the Length Matter? Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   Does the Length Matter? Empty Re: Does the Length Matter? Fri Mar 25, 2022 7:09 pm
Woodie
Woodie
Make your own custom cable maybe?  Paul Brodie covered it in one of his YouTube videos and it is definitely not rocket surgery.
Does the Length Matter? Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
4Back to top Go down   Does the Length Matter? Empty Re: Does the Length Matter? Sat Mar 26, 2022 8:33 pm
Thomas
X shows which cables are used on which bikes:
Does the Length Matter? ICHA7Kp
5Back to top Go down   Does the Length Matter? Empty Re: Does the Length Matter? Sun Mar 27, 2022 7:38 am
Woodie
Woodie
Sorry tjh1985, completely missed the part where you mentioned that you had already tried the diy option.
1985 K100RT  52667
