1 K75s Problems-help appreciated! Tue Jan 18, 2011 6:11 pm
netaron
Hello everyone,
Just picked up a 93 K75s with around 42K miles that had been sitting for about a year; she is very un-willing to accelerate under load. When the bike is on the center stand, it revs just fine (most of the time), but when taking off, she will hesitate and completely die sometimes. It also idles around 2K with the fast idle (choke) disengaged and engine fully warmed up, and the idle screw up, so there is something else happening. When accelerating, the engine wants to die, unless I back down and carefully twist my way up. It will accelerate even when I am riding it, but after about a minute, it will just run out of power and slowly die.
I have all service records and the bike was well maintained; the only issue was that the previous owner complained about hesitation and asked the dealer to check the injectors, they did and found nothing. Not sure why they didn't investigate further. I read some previous posts on this forum and tried to resolve this problem without having to post a new topic, but was hoping to get some direction before spending more time and funds.
This is what I have done so far:
1- Completely re-charged battery (engine turns over crazy fast)
2- Checked old fuel in tank; the fuel looked like apple juice
3- Removed all the old fuel from the tank
4- Added 2-gallons of fresh good quality fuel
5- Added a bottle of Heat fuel water dryer
6- Ran the engine for a very long time, and took it out for a ride a few times
7- Checked Plugs-they were sooty and black, not wet-sanded them with fine sandpaper, cleaned and re-installed
8- Checked Plug cables, tested OK, but why the last cylinder closest to the coils has the longest spark plug wire is beyond me
9- Checked Fuel injectors-cleaned, soaked in carb cleaner overnight, used 9volt batter with connector to apply voltage to each injector, they seemed to operate and fed more carb cleaner through them while voltage was being applied
10- Re-installed injectors and tested them on the rail; they injected all at similar rates while trying to start the bike
11- Replaced a cracked S shaped hose that seems to connect the air cleaner housing to the throttle-body
12- Checked air cleaner- still looks new
13- Oil level was a little high-it was past the high circular mark, removed excess oil
14- Checked all hoses around the throttle body and air filter housing, they seem OK (but I have not removed the tank yet for a closer inspection)
15- Used the propane trick around the throttle body, air filter housing area to see if engine RPM would rise without any luck
16- Fuel pump seems to work; it runs on for a second or so after engine dies (obviously more testing needed here)
17- Checked the tank and the 2 new added gallons of gas looks a bit murky (possible old residue in the system)
18- Checked exhaust- it does not smoke (not that I can tell at least)
19- When opening the tank lid, it does make that air surge noise
Since the fuel was replaced, it runs much better, but after all the other work, the rough running under load still persists.
I think that is all I have done so far.
Thank you all.
Aron
Thank you all.
Aron
