1Back to top Go down   Hall sensors  Empty Hall sensors Tue Aug 16, 2022 4:38 am
Jibe
Jibe
Hi all been chasing a miss fire that got worse to the point the bike would cut out but fire up once cooled down. Unmistakable symptoms of hall sensor packing up. I've ordered and fitted to the plate  two CYHME56C.
My question is the cable colour of the red black and green is the same configuration as the orginal stock halls ?? Don't fancy smoke bang and no Genie ........
2Back to top Go down   Hall sensors  Empty Re: Hall sensors Tue Aug 16, 2022 11:43 am
A genie-less bang is the very definition of disappointment. Smile
If you scroll through this Chen Yang data sheet you'll find its wires labeled on the last page; you can then compare them to the labels in the troubleshooting guide here.
3Back to top Go down   Hall sensors  Empty Re: Hall sensors Tue Aug 16, 2022 12:11 pm
Jibe
Jibe
Laitch wrote:A genie-less bang is the very definition of disappointment. Smile
Thanks Laitch I'm confident now after cross references between new and old. Just the inner me thinking how wrong it seems hooking up the reds to the k100 black cable 😆
4Back to top Go down   Hall sensors  Empty Re: Hall sensors Tue Aug 16, 2022 1:25 pm
5Back to top Go down   Hall sensors  Empty Re: Hall sensors Tue Aug 16, 2022 1:32 pm
Jibe
Jibe
Just fired the old girl up with a nice smooth tick over. The test comes on a run, fingers crossed the problem has done one
6Back to top Go down   Hall sensors  Empty Re: Hall sensors Tue Aug 16, 2022 1:41 pm
Jibe
Jibe
Took a pic before the snip always handy .....looking at your last post I could have made a possible mistake. I've followed my pic and she fired up so it's gotta be right Hall sensors  20220810
7Back to top Go down   Hall sensors  Empty Re: Hall sensors Tue Aug 16, 2022 3:04 pm
bad boy
bad boy
well done, Jibe Hall sensors  112350
Cheerz, David
Hall sensors  9438-010
8Back to top Go down   Hall sensors  Empty Re: Hall sensors Wed Aug 17, 2022 7:03 am
Jibe
Jibe
Test ride done seemed better but unfortunately is still present 😠 looks like the tools need to come out again, anybody had a similar problem after replacing HEF's and still misbehaving??? I'm fairly sure it's electrical as bike performs spot on before it warms up.
Checked coolant temp cold reading on both sides good had another maf tried that the same thing. New NGK leads and plugs, coils tested and seem to be good. Checked earth's all at 0.5 ohms also new injectors. I've got no air leaks but have noticed a blow at the manifold to down pipe but I don't think that would cause my problem. Any advice would be greatly appreciated.
9Back to top Go down   Hall sensors  Empty Re: Hall sensors Wed Aug 17, 2022 10:59 am
What exactly is the misbehavior, Jibe?
10Back to top Go down   Hall sensors  Empty Re: Hall sensors Wed Aug 17, 2022 12:13 pm
Issues on heating up in my book would likely relate to coils and plug leads and also possibly plugs. Bear in mind one normally runs tests on coils when the coils are cold. In the days of yore on 70s cars I had not infrequent falures on coils due and distributor caps due to cracking and tracking.
See if you can use a heat test [gloved hand] to determine if you can isolate a faulty cylinder [or two]. Hall sensor fault does not affect a single cylinder but two, either 1/4 or 2/3. Same for coils.
I have not read all the posts but a tight valve will on heating up expand and may then not close fully resulting in loss of compression in its cylinder giving a misfire. I would start at the exhaust valve clearance in the cylinder with the slight blow.
One component that can be affected by heat is the ICU under the headstock.. . . .
11Back to top Go down   Hall sensors  Empty Re: Hall sensors Wed Aug 17, 2022 2:45 pm
Jibe
Jibe
Really thought I would have cracked it with the hall sensors what with new ht leads and plugs. It's starts missing when it warms up and get worse all most violent, the weather was extremely warm when it cut out before changing the halls and started up once cooled. As for heat checking cylinders, quite honestly I don't expect to feel any difference as it clears quickly and back to judder again down the road this is at any rev range past idle. My next plan is to go through all connections and if still the same think about replacing the icu ..... intermittent faults are a pain in the @rse
12Back to top Go down   Hall sensors  Empty Re: Hall sensors Wed Aug 17, 2022 4:30 pm
moriarti
moriarti
Hi Jibe, I had a similar problem baffled me and my mates. Krazy Frog suggested the ICU, fitted a S/H unit solved the problem, the little buggers are responsible for all sorts annoying cockups. Crying or Very sad Crying or Very sad
13Back to top Go down   Hall sensors  Empty Re: Hall sensors Thu Aug 18, 2022 3:56 am
Jibe
Jibe
Thanks for the advice I will check over the bike soon as I get time and look to enquire on a replacement ICU. These things are set to challenge us and part and parcel of keeping a little bit of history on the road
14Back to top Go down   Hall sensors  Empty Re: Hall sensors Thu Aug 18, 2022 7:44 am
Jibe wrote:Thanks for the advice I will check over the bike soon as I get time and look to enquire on a replacement ICU. These things are set to challenge us and part and parcel of keeping a little bit of history on the road
The reason I mentioned the ICU is that I had a similar issue on my K100LT and this was the cause. Unfortunately running tests does not work because it was failing under heat and most tests done cold wont identify that.
15Back to top Go down   Hall sensors  Empty Re: Hall sensors Thu Aug 18, 2022 7:55 am
Jibe
Jibe
Bite the bullet and replace the ICU, trouble is S/H is still years old, we are for ever gonna chase problems but that's part of the fun well sometimes.......
16Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 12:31 pm
Jibe
Jibe
Getting the hump now ....replaced hall sensors, replaced icu replaced maf new plugs and leads tried another set of coils new ev14 injectors.
Earth's are all good and no obvious air leaks. I think i can rule out ignition all but timing the bike pulls hard right up to the red line when cold. Temp sensor appears to give correct resistances. Ecu plug looks clean. I'm pulling my hair out here any ideas cos I'm officially running out of them
17Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 12:45 pm
Jibe wrote: Temp sensor appears to give correct resistances.
What are the readings that you are getting?
18Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 2:20 pm
Jibe
Jibe
The bike has been out for a test run (failed) in the shed cooled down at the sensor was reading 1.6k ran the bike for about 8 minutes I got 420 ohms. I have to be honest I only checked cold resistance before which was at 2.5k
19Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 2:45 pm
Jibe
Jibe
Just ran it hot 170 ohms fan never cut in. It might be as simply that's its over heating will take a look at the fan relay and wiring tomorrow
20Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 4:58 pm
What year  and model K?
(It helps others help you if you put that in your user profile signature.)
21Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 5:07 pm
92KK 84WW Olaf wrote:Issues on heating up in my book would likely relate to coils.
I've seen this before on an 85 K100 that ran crappy when it heated up. Swapped in a different pair of coils and the problem went away.
22Back to top Go down   Hall sensors  Empty Re: Hall sensors Sat Sep 10, 2022 5:21 pm
Jibe wrote:Just ran it hot 170 ohms fan never cut in. It might be as simply that's its over heating will take a look at the fan relay and wiring tomorrow
Is the temp light in the cluster coming on? That should happen at around 144 ohms or lower. (111 degrees C)
When it gets even hotter (120 C) then the radiator cap should blow. (Just like a car does.)
To test if your cluster temp bulb is working you can ground Pin A3 of the temp relay socket and turn the ignition on. (Violet/black wire.)
23Back to top Go down   Hall sensors  Empty Re: Hall sensors Mon Sep 12, 2022 3:30 pm
Jibe
Jibe
Well I fired it up today it ran up and the fan kicked in OK. Just can't understand what's going on new plugs leads s/h icu, coils new halls maf also only thing I've not replaced is the ecu. I thinking it's fueling now. The tank is spotless inside with a newish pump and filter along with the coolant sensor. When's its cold it's right on the money just can't understand what's going on I'm at a total loss at the moment any ideas people 🤔 as I'm stuck ..........
