1 LED globe problem on Kronies Workshop Day Mon Jan 16, 2023 5:38 am
On our workshop day SSD decided to change his headlight globe over to LED adjustable with heat sink no fan. After changing out the globe they found that they only had one beam. Changing from high to low and even hitting the flasher they still only had one beam. As the globes came as a pair they tried the second globe and they had the same results. Going back to the standard globe fixed the problem. I gave them my spare LED globe, adjustable, heat sink with fan and it had the same problem, one beam. Matt and Gary the Greater ( both Sparkies) checked the wiring and found no problems, it has been fitted with relays. Refitting the OEM globe fixed the problem every time. I didn't have much time yesterday but had a quick look before SSD took off home. I could not find any problems with the set up. This morning I decided to check my spare globe out. Due to the brightness I put on my auto dimming welding helmet and found that the high beam LED was not working. The globe was not running through the headlight wiring but connected to jumper wire setup connected to the accessory outlet for testing purpose. The only theory at this stage is that the globes are faulty which makes 3 faulty globes from two different manufacturers. My spare globe has been sitting in its box for around 4 years and has never been connected to any power. I've told SSD to take the globes back to the supplier and get a refund or new globes. I can't see that anything done during the fitting process would cause them to fail.
