1Back to top Go down   Greetings from Michigan Empty Greetings from Michigan Mon Feb 20, 2012 2:47 pm
sd8885
sd8885
Hello friends,
Thanks to all who have posted technical tips to the forums. Your experience has been very helpful to me while starting restoration of an 85 K100RT barn find.
The bike had been sitting for six years with enough fuel in the tank to melt the fuel pump damper. The fuel pump still works OK, but the injectors are not firing. I plan to test the electrical this week and if good, replace or clean the injectors.
-Scott
2Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Mon Feb 20, 2012 4:15 pm
g35corona
g35corona
Welcome aboard Scott. That bike will be running like new with help from the folks on this forum.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
3Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Mon Feb 20, 2012 4:59 pm
Oldgoat
Oldgoat
Barn find's are always fun! Welcome aboard Scott & post a pic if you get a chance?
OG
4Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Mon Feb 20, 2012 7:05 pm
Welcome Scott. Nice part of the world you're in I've visited your State on 3 Occasions. Good roads for biking. looking forward to seeing some pics of your barn find.
88KE
Greetings from Michigan Ir-log1188....May contain nuts!Greetings from Michigan Ir-log11
K75RTP - 1994
5Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Mon Feb 20, 2012 7:18 pm
Welcome to the forum Scott. Aren't barn finds interesting you just don't quite know what to expect.
How about you start a thread on the restoration so we can all share.
6Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Mon Feb 20, 2012 7:41 pm
krambo
krambo
Welcome aboard Scott - loads of help and suggestions (some are even polite) to be found here Wink
"Aut viam inveniam aut faciam." Greetings from Michigan Uk-bmw12
http://www.its-personal.net
7Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Tue Feb 21, 2012 7:52 pm
sd8885
sd8885
Thanks for the suggestion to post pictures. She was sitting in the back of a garage for 6 years.
Looking good from a distance...
Greetings from Michigan Img_0413
Found a melted rubber fuel pump damper...
Greetings from Michigan Img_0411
all cleaned up...
Greetings from Michigan Img_0511
So far I've been blessed! The fuel pump is working fine. Glad I didn't power it up with the old fuel.
-Scott
8Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Tue Feb 21, 2012 9:15 pm
krambo
krambo
Those images will look familiar to some our members I'm sure - keep em coming buddy Wink
9Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Tue Feb 21, 2012 9:19 pm
sd8885
sd8885
Update: The old fuel didn't smell or look good.
Greetings from Michigan Img_0512
Much better after flushing with some fresh 91 octane. Very Happy
Greetings from Michigan Img_0513
Now searching for new injectors. Anybody try the 4-hole spray pattern Bosch injectors as an upgrade?
Greetings from Michigan Img_0515
FYI - The high pressure fuel from the pump goes in the front fitting and out the rear (left to right in picture).
-Scott
10Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Tue Feb 21, 2012 9:23 pm
You are at the right place to get help.
Thanks for the pic. Hopefully we will have the opportunity to follow your progresses.
Cheers,
CF
Greetings from Michigan Frog15Greetings from Michigan Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
11Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Tue Feb 21, 2012 9:25 pm
sd8885
sd8885
BTW - The fuel will not flow through the pressure regulator in the wrong direction. Tried it while flushing the lines. Oops. Only got a little wet. However, it got me thinking...
SAFETY REMINDER: Always work in a well-ventilated area with no open sources of flame or sparks when working with fuel. :pale:
12Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Tue Feb 21, 2012 9:37 pm
Humm, You get flow and not pressure from the pump...
Try to block the hose coming out of the tank. The pressure should be around 65 PSI and you should not be able to block it. If you do, it may may be as a result of a stocked relieve valve on the fuel pump(#1 on the following schematic).
Greetings from Michigan Fuel%20pump
13Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Wed Feb 22, 2012 5:31 am
BIG D
BIG D
Cool
Hi and welcome Scott nice looking bike,
BIG D
14Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Fri Feb 24, 2012 7:41 pm
Hi Scott,
Great to have you with us.
When discussing bike fixes please post it in the appropriate section since not everyone reads the new member section and you may then miss getting the wisdom of the specialists in your problem.
15Back to top Go down   Greetings from Michigan Empty Re: Greetings from Michigan Sat Feb 25, 2012 2:30 pm
sd8885
sd8885
Thanks. Will do.
