Number of posts : 11689
hi nizza .....welcome mate
there is a design problem with headlamps and the over wattage type lamps we like to install ...
the switch gear (read wiring and switches ) do fine with "standard " design ratings ...but the wiring is only rated for this ....we have seen the insulation being stripped from the wiring (and causing all sorts of problems ) from the extra heating effect of the current going to these ."over rated " headlights on many occasions .
may i offer a couple of suggestions .
firstly the connector on the actuall headlamp could be corroded ...or suffering from the dreded heating affect of the extra temps that higher wattage globes produce ...the replacement connnections are easily obtained ...but the "best option " is to replace with a ceramic type plug
undo the tank and check the multipole connectors going to each handle bar .....what you are looking for initially is any sign of heating effect on the insulation of the cables ....and the connectors in there.
we have found that "deoxit" is the prefered electrical connector cleaner for all sorts of issues (available from jaycar here in aussie )
over time the switch contacts in the switch assemblies ( both sides ) could corrode up ...become brittle (heating effect and general corrosion ) and may need a good clean .
but caution should be observed when attacking the switches ...lots of small bits that could fly off and never found again ,
what im reading in your description ...is that the bulb monitoring circuit is being activated durring operation of the main headlamps
this could be caused by voltage drop and dirty connections to the rear taillamp assemblies ...so i would recommend a good clean of the tail lamp and its associated spade type lugs in and around the lamp holders there ......also a good idea to change the bulb for the same wattage and clean up the spring loaded contacts that make the connection to the globe .
dont forget that the little "parkers" globe ..just above the headlight assembly is a commonly overlooked part of the lighting circuits and should be at a minimum cleaned connections and replace the globe .
many of us have installed extra wiring and relays to bypass the switch functions for the head lamps being affected ... well so that they still work but are carrying only relay current for the switching to the relays now ...
we have found some positive results from this ....and if you want to continue with the brighter lamps i really recoment this "upgrade "
there are lots of threads refering to this throughout the forum ....just look up "relays" with the search feature
hope this help somewhat
good luck
if you need extra help we are conducting a "workshop" get together on the 14th of april up in kingaroy and im sure of the guys attending we could help point in the right directions to the fix or assistance at a minimum
