1Back to top Go down   oil sump Empty oil sump Wed Apr 11, 2012 1:46 pm
lesso
lesso
anyone recomend the type or make that i require to put sump cover back on.
2Back to top Go down   oil sump Empty Re: oil sump Wed Apr 11, 2012 2:27 pm
I`ve got good results on the metal to metal joints with Permatex black RTV.
3Back to top Go down   oil sump Empty oil sump Wed Apr 11, 2012 2:28 pm
lesso
lesso
thanks
4Back to top Go down   oil sump Empty Re: oil sump Wed Apr 11, 2012 2:38 pm
mike d
Inge knows his stuff, or you could according to the BMW K100 manual:
Oil sump - installing
The sealing faces on the crankcase bottom section must
be free of oil and grease. Apply a thin coat of Three Bond
1207 B
to the sealing faces. Offer up the oil sump.
Uniformly tighten the oil sump retaining screws (arrows).
Install the drain screw with a new sealing ring.
Tightening torque:
Retaining screws 7 ± 1 Nm
Drain screw 32 ± 4 Nm
5Back to top Go down   oil sump Empty sump clean Wed Apr 11, 2012 3:37 pm
lesso
lesso
anything i should use to clean the metel to metel with to ensure all grease oil dirt off. sorry but first time for me a novice
6Back to top Go down   oil sump Empty Re: oil sump Wed Apr 11, 2012 5:13 pm
mike d
Brake cleaner.
Mike
7Back to top Go down   oil sump Empty brake cleaner Wed Apr 11, 2012 5:41 pm
lesso
lesso
thanks all comeing to-gether
