1Back to top Go down   Current tester Empty Current tester on Sun Apr 29, 2012 4:52 am
Albyalbatross1
Albyalbatross1
While I was in our local auto shop buying some spare fuses i noticed a this great little 20 amp 12/24v test unit. It alows you to test the current draw on the circuit for the fuse you are having issues with or just want to see what your headlight, spots ect is drawing.At only $10.00 I thought i should give it a go. A whole lot cheaper than
a 20amp multimeter and This device just plugs in place of your fuse.
You need to make sure you place the fuse from the wedge socket you are
testing into the plugs fuse holder or NO FUSE PROTECTION. It wont work
with out it anyways. I used my resettable blade fuses.
Current tester Resize61
All you do is remove the fuse and plug in the tester,Turn it on and start your bike..Read off the display. It will contiue to read any load you add on the circuit and can be left in place for watching the actual draw while in motion. It will also indicate polarity as well. I tested the current draw in a few sockets and it works well.
I think will be a useful fault finding tool.
High Beam
Current tester High_b10
Spots with High beam
Current tester Resize62
And the instrument/brake fuse socket.
Current tester Access10
2Back to top Go down   Current tester Empty Re: Current tester on Sun Apr 29, 2012 5:12 am
wow ...a great tool alby ...and the price is right ....way cool Current tester 112350
you could also do the same with a .1 ohm resistor (calibrated of corse ) and just measure the voltage drop across it = direct reading of amps to volts should be real easy + the extra decimal point .
but this tool is way cool ...all the work is done .....cheers ..
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OCurrent tester Au-log10
3Back to top Go down   Current tester Empty Re: Current tester on Sun Apr 29, 2012 3:29 pm
Nice one Alby, I've just ordered one from Maplins UK.
Cheers,
4Back to top Go down   Current tester Empty Re: Current tester on Sun Apr 29, 2012 4:14 pm
Nice unit, also available in the UK: http://www.maplin.co.uk/automotive-current-tester-217879.
It doesn't seem to be available in North America Crying or Very sad
Current tester Frog15Current tester Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   Current tester Empty Re: Current tester on Sun Apr 29, 2012 4:29 pm
Even cheaper at the Farnell site.
6Back to top Go down   Current tester Empty Re: Current tester on Mon Apr 30, 2012 5:58 pm
Yes Inge, But their delivery/handling charge makes it £1 more expensive!
7Back to top Go down   Current tester Empty Re: Current tester on Mon Apr 30, 2012 6:47 pm
Thanks Paul, then they`re not gonna be my first choice.
8Back to top Go down   Current tester Empty Re: Current tester on Mon Apr 30, 2012 8:25 pm
Tom FKR
Tom FKR
G'day Alby,the current tester is a great unit.After reading your post I hotfooted down to the local auto shop and bought one.The shop said they were a discontinued line because of poor sales.Cheers Tom
9Back to top Go down   Current tester Empty Re: Current tester on Tue May 01, 2012 10:34 am
farnell ....hahahhahahah yourve got to be joking ....and no i havent seen the link .....(hides quietly in the corner)
10Back to top Go down   Current tester Empty Re: Current tester on Wed May 02, 2012 5:38 pm
Add a pair of lucar connectors with leads to croc clips and, hey ho, its a 'use anywhere' 20A ammeter.
Current tester Ssl10910 Thanks again, Alby.
11Back to top Go down   Current tester Empty Re: Current tester on Thu May 03, 2012 4:17 pm
Clever one, Paul.
12Back to top Go down   Current tester Empty Re: Current tester on Fri May 04, 2012 5:59 am
Albyalbatross1
Albyalbatross1
paul, I had the same idea except I used a fuse wedge with clips on each end. same result.
13Back to top Go down   Current tester Empty Re: Current tester on Mon Jan 09, 2017 10:31 am
Tom Grabau wrote:G'day Alby,the current tester is a great unit.After reading your post I hotfooted down to the local auto shop and bought one.The shop said they were a discontinued line because of poor sales.Cheers Tom
They are available on Ebay.  Not quite as cheap, but still not bad.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=blade+fuse+current+tester&_sacat=0
