1Back to top Go down   shifter shaft screw tightening. Empty shifter shaft screw tightening. Tue Jun 26, 2012 9:16 pm
scout18
scout18
I'm about ready to pull the transmission to get at this little screw that keeps the shift shaft from moving past it's stops. I want to pull the tranny with the final drive intact. This seems pretty straight forward. Any helpful comments are appreciated. Thanks for all the help so far folks.
2Back to top Go down   shifter shaft screw tightening. Empty Re: shifter shaft screw tightening. Tue Jun 26, 2012 10:42 pm
They will come out like that but its a two person job to get it in and is a real PITA, to be honest you would be far better to disassemble it all and check things as you go and lube the splines as well
3Back to top Go down   shifter shaft screw tightening. Empty Re: shifter shaft screw tightening. Tue Jun 26, 2012 11:46 pm
scout18
scout18
Too late, I had it cribbed up nice to catch it though. With only 37,000 miles on it I'm going to gamble a little. I'm not even sure I'm going to like it. I may have to get a more up right bike or RT handlebars for it Surprised
4Back to top Go down   shifter shaft screw tightening. Empty Re: shifter shaft screw tightening. Wed Jun 27, 2012 12:53 am
It may only have 37k on it but it is 25 years old and grease dries out. For the little bit of time is it really worth thr chance.
5Back to top Go down   shifter shaft screw tightening. Empty Re: shifter shaft screw tightening. Wed Jun 27, 2012 2:12 am
scout18
scout18
Good point Rick. I'll have to address that too. Thaks for the tips.
6Back to top Go down   shifter shaft screw tightening. Empty Re: shifter shaft screw tightening. Wed Jun 27, 2012 4:47 am
caferacer62
caferacer62
Would have to agree with Rick on this one. Much cheaper to grease the splines on everything while you have it apart.
The alternative is far to expensive.
Bert 2.0
shifter shaft screw tightening. 170874
7Back to top Go down   shifter shaft screw tightening. Empty Re: shifter shaft screw tightening. Thu Jun 28, 2012 3:52 am
scout18
scout18
After I get that tranny back in I'll take that business apart to lube it up. I got the screw cleaned up loctited in and the cover put on without any real drama.
