1 Stripped drain plug in final drive case. Thu Aug 23, 2012 8:13 pm
...or how to have a ridiculous afternoon.
It was 20C in Guyra today...like summer after so much winter weather. I had a few errands to run and decided to drag the outfit out of the shed and strap the dog in. We had a bit of a wander about and then I decided to make use of the warm engine and change the gearbox and final drive oil. Did the gearbox oil and then while putting the drain plug back in the final drive casing, I felt the thread let go. Not all the way tight...and it really started spinning freely...not engaging any thread. I knew immediately it was going to be a problem...and I also knew it was my own silly fault, as I had sensed it was a dodgy thread last time I had changed the fluid. I tried a couple of tricks to no avail and then decided to take it around to my mate Dave's place, as he is more adept at things mechanical than me and also has a proper shed. In the end we had to tack weld a piece of metal onto the plug to get enough on it to engage the thread and finally get it out.
Of course, the plug is steel and the casing itself is alloy, so naturally, it's the casing thread that is kaputt. It will require tapping etc and another plug. Oh well, said I to myself...this will give me the opportunity to try that other final drive that I got off Rick. It's from a 75 and will lower the gearing. Be interesting to see how it goes, power wise etc.
All went well until I went to insert the new drive into the shaft.....and yes.....you guessed it...it has too many teeth! I hadn't even thought to look at it beforehand.
Oh well.....I have two more spares...one of which feels ok, though I haven't actually pulled it apart to check the bearings....will whack that on to keep the bike roadworthy while I fix the other one. By the time I had that done, it was dark and I have no power in the shed, so will have to wait until morning to put the rear wheel back on. Installing the 15" rim is a cow of a job...the weight of it combined with the recessed fit with the adaptor makes it stupidly difficult with that spacer! Morning.
Ah well...yer get that.
Anyone need a final drive? Will swap it for something or other.....
Sean.
Sean.
