Number of posts : 7897
UK Kev
You might be able to do just by raising the rear of the tank.
I lengthened my fuel lines slightly [perished so used longer replacements] so I can lift tank well clear to access relay box wouth disconnecting the fuel lines. I alos relocate dthe earth from the tank to allow this. I now only have to separate the fuel pump connectors and they are easy to get to. I prop the rear of the tank and have full access with a bendy screw driver and either cross head or socket to remove any of the relays or units.
If you are doing this just after running the bike disconnect the fuel pmp line sand rin the engine until cut out to remove the fuel pressure.
Its not a difficult job. I have to remove fairing left side knee panel and storage pocket and also the 2 internal baffles but they are easy to do.
92KK
1971 Yamaha 125 YAS-1
