1 Accessory plug Fri Oct 12, 2012 6:25 am
chrish8846
I installed some running lights today and wired in a relay just to make sure nothing was overloaded, and popped my battery charger into the accessory plug to top the battery off and noticed that the charger was not charging. Checked around and found power to the plug but no ground,checked ground from battery to plug wire and it was good?? whats up??Checked further and found that the ground was bad at the accessory plug body, soldiered plug wire to plug body and all is well again. I thought it very unusual that the riveted connection was loose and making poor contact.
