1Back to top Go down   Cables - OEM or pattern Empty Cables - OEM or pattern Thu Jan 31, 2013 1:46 pm
MT350Explorer
MT350Explorer
Hi Guys
Is there a way of telling if a clutch cable/throttle cable is OEM or pattern by looking at it?
Dave
1991 K100 RS 16 valve
2Back to top Go down   Cables - OEM or pattern Empty Re: Cables - OEM or pattern Thu Jan 31, 2013 3:09 pm
BMW's OEM cables generally have a part number printed into them near one end. It's usually the last seven digits but often the entire part number a long with a small roundel is visible.
~Mac McCleary
3Back to top Go down   Cables - OEM or pattern Empty Re: Cables - OEM or pattern Thu Jan 31, 2013 3:17 pm
+1........always at the upper end,....on the ones I have seen.
4Back to top Go down   Cables - OEM or pattern Empty Re: Cables - OEM or pattern Thu Jan 31, 2013 4:45 pm
MT350Explorer
MT350Explorer
Cheers Guys Very Happy
