1Back to top Go down   Oil spitting while on the throttle Empty Oil spitting while on the throttle on Wed Jun 19, 2013 6:09 pm
albomoto
albomoto
Hello all. I just put the bike back together after replacing the throttle cable and I noticed some oil that spits out on the exhaust right where the collector is before going into the muffler. It also drips on the side kickstand. The bike also sputters a bit so I believe a cylinder is missing but I don't think the two would be related. Only that I've never had the problem before. The engine and transmission look to be dry and I can't quite seem to locate the leak because it's hard to see up there. Any ideas?
2Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Wed Jun 19, 2013 9:55 pm
Is it gear oil or engine oil, you can tell by the smell.
3Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Wed Jun 19, 2013 10:05 pm
albomoto
albomoto
I believe it's engine oil. Too thin to be gear oil and it doesn't have that smell
4Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Wed Jun 19, 2013 10:07 pm
albomoto
albomoto
I didn't see anything on the backside of the engine leaking though
5Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Wed Jun 19, 2013 10:33 pm
Its possible the oil is comming from the oil return drains which are on the under side of the head and it usually drips down onto the pipes a bit futher forward but may be running back along the block till it drips of above the colector. My wifes K75 is doing it at the moment and will need attention before we go away in september.
6Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Wed Jun 19, 2013 11:01 pm
albomoto
albomoto
I'll check it out. Thanks for the suggestion
7Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Thu Jun 20, 2013 4:40 am
or is there a crack in the crankcase breather ? dripping down behind the coil packs ... then onto the exhaust ?
just a thought
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OOil spitting while on the throttle Au-log10
8Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Thu Jun 20, 2013 1:04 pm
albomoto
albomoto
The crankcase breather is cracked but not dripping enough to cause this. I have a replacement hose to fix it though
9Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Sat Jun 22, 2013 2:20 am
Hi There,
Post your question in the relevant section of the forum because not all the gurus read the new members section and you might not get their input.
10Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Sat Jun 22, 2013 8:25 am
albomoto
albomoto
Thanks, I'll do that
11Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Sat Jun 22, 2013 8:29 am
Moved to the relevant section for you albomoto.
12Back to top Go down   Oil spitting while on the throttle Empty Re: Oil spitting while on the throttle on Sat Jun 22, 2013 9:05 am
albomoto
albomoto
Thank you blakey
