Number of posts : 7897
Welcome to the site.
You are in the right place.
Have a look at the section You have just bought a K Bike. One you have 3 posts in here you should set up a thread and we will add our bit. Also get your hands on a Clymer manual. Everything you need is here but its hard to beat the manual too.
It looks like some TLC needed but that's often the case with low mileage bikes especially if they have been off the road.
The spongy brake pipes cause weak braking. New steel braided pipes will cure that. The spongy feeling is a normal sign of deterioration but must be fixed. K brakes when they are right are really good. You should do all the hoses but the ABS system means it needs to be done carefully and you need a power bleeder. there should be a section on it here too.
Panniers and Z frames can be got off eBay or someone here might have a set.
I suspect a spline lube and check of seals is on the cards too.
ABS advice here too, needs expertise but some remove the ABS rather than spend money to fix it. The brakes will work fine. However if you are determined it is worth exploring as there are a few items like wheel sensors and more that are cheap. The biggest issue is dodgy electrical connections because of age and this too can affect the ABS system so you need to carefully deal with that. Even without a wiring manual you can do it if you simply open one joint at a time and deal with it before going on to the next. This is a tedious but cheap exercise needing some Deoxit and patience. It is a great way of getting to know the bike too.
There are a few other things too. Fuel hoses perish, replace them. If brake lines are bad chances are these will be perished as well. Use only the BMW ones, they are cheap but its a tank and top half airbox off to do it- you will have tank off to do electrics anyway, battery out too [easy] gives you much more room. Also do the coolant pipe from the radiator to the overflow, its cheap but perishes too. Same with the sightglass pipe on the side of the coolant bottle, again an easy fix. If the battery is out you will see two allen bolts on the left side which hold down the starter motor. It too comes out [give the bolts WD40 first] easily and worth cleaning it inside. With the low miles the brushes should be fine but cleaning improves electrical performance.
Get your 3 posts up and start a thread, we will all add our bit The bike needs tlc so don't use without fuel filter change and get rid of the gasoline in the tank. Ethanol in the gas causes problems but replacing the filter and a few other bits inside will save some frustration.
A word of warning, make sure the battery is good and known to be good. A bad battery can fry the starter relay and cause a lot of other problems and false readings. This is first on the list before doing anything.
I hope it doesn't all sound a lot. I got an 84RT some weeks back and did a lot in 3 days. I had issues like stripping and painting stands and part of the frame, changing heat shield and more. I still have some jobs to do like the fork seals, head bearings and will also change brake lines.
The thing I found is there will always be someone around to help you with things. There can be fun when two or more get together for a workshop session to tackle jobs that need extra expertise or manpower and do 2 or 3 bikes. Just make sure you have the right supply of parts and you will get that advice here too.
Best of luck with it.
Last edited by 92KK K100LT 193214 on Sat Sep 21, 2013 7:41 am; edited 2 times in total
1971 Yamaha 125 YAS-1
