1 The how not to restore bikes thread Thu Mar 13, 2014 12:38 pm
Speedaddictedberk
This is the saga of my 1986 K100 restoration. Be warned that I take a lot of pictures. Really a lot of pictures.
I have an 85 GPZ600R (ninja in the states) that I re-built and I liked the idea of another project. I wanted an R90 to cafe racer but stumbled across an unhappy looking K100.
It had been sat for a while and was in a pretty sorry state, so I bought it. Because I'm an idiot.
So I began to strip the bike down. It had been taken off the road after many miles and no care taken because the cllutch release had seized. Easy job, cosmetic tidy up and I have a big bus to trundle about on.
I should have looked at the level of corrosion and run away. Sensible people do things like that. Or the state of the engine.
When I took off the exhaust to get access to the clutch release on the back of the gearbox the front exhaust ports crumbled away, it had been previously crashed and the head was buggered. Not a happy day. Sensible people would have stopped now.
So I got hold of another head.
And some forks because the ones it came with were pitted under the seals, so when I took them off they started to leak. And a shock that worked. And a seat that wasn't rusted through. Lots of stainless bolts though, because lots were too nasty to re-fit.
Got the frame powdercoated though
Quite a big jump here, obviously too busy fitting bits to photo. managed to paint the cases in an enamel that's about as tough as wet paper, they looked nice for about a week.
Moved house, big gap in bike stuff.
Then I left the bike on the ramp while I went offshore for two weeks. When I came home it had jumped off and fecked the side panel. Oil and battery acid everywhere.
Hence a new streamlined look!
Most recently the clocks have been moved lower down, they'll eventually be replaced with a smaller digital unit. Lots of messing about trying to find air leaks involved stripping it down again and replacing any rubber parts that were left the first time round.
Oil leaks solved with helicoils and swearing. Radiator leaks solved with another radiator.
Finally got the throttles balanced thanks to a thread on here and it's running sweet! I'll give it another going over to try to ensure that it's all OK before taking it for the MOT. I'll ride it for a while before getting it painted but I quite like the blue. I've had four other bikes in the time it's taken to get to this stage so no need to hurry now!
It may be getting chopped and having clip on bars fitted next. No idea how long that'll take though.
