1Back to top Go down   blown bottom end gasket Empty blown bottom end gasket Sat May 03, 2008 8:19 pm
xody.prodigal
i was riding my 91 k100 around yesterday and my RPM's would not return to normal idle nearly as quickly as it should, and i could feel excess heat comming from the engine. so i pulled over and took a look at the throttle lines and the rest of the engine. there was liquid (i believe to be oil and/or gas) bubbling from a small point in the gasket, where the bottom end bolts to the rest of the engine. i am fairly sure that it is a blow gasket. but i'm not positive. does anyone know about this problem? ANY info is more than welcome
thanks
