1Back to top Go down   Temperature Relay Empty Temperature Relay on Mon Apr 06, 2015 1:53 am
Oliveri
Oliveri
Hi everyone,
Just read 'floyd's' thread re. Temperature Relay - Cooling fan not working. It appears that i'm having similar issues. Tested all possible connections but cant get the fan to work by jumping the sensor connections ("E" with the relay present in the socket).
So I opened the relay: Temperature Relay Temp-relay
...as you can see there is a burnt out circuit (on the left). Same spot as floyd's.
Hmmm, what to do now? Can this be fixed (bridged with solder)? Or do i need to buy another? If i do need a new one, where can i get one for a reasonable price.
"Keep the paint up, and the rubber down
Temperature Relay Bike
1988 K100RT...#0096960 ..."Heisenberg" ...Status: Work in progress
http://www.vintagesteelworks.com
2Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Mon Apr 06, 2015 2:55 am
I'd do the solder bridge first.  But before I fired it up I would be checking the external wiring the burnt trace connects to.  Who knows, maybe it will work.  At least if there is still a problem you won't be burning up a new temperature module.
3Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Mon Apr 06, 2015 3:18 am
see if the fan is seized first ....could be drawing heaps of amps on activation
get a stick and try and turn the fan ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OTemperature Relay Au-log10
4Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Mon Apr 06, 2015 3:46 am
Oliveri
Oliveri
...everything appears to work fine when i 'bridge' the contacts on the relay connector plug.
 - Fan works
 - Overheating light works
I also tested the resistance on the temp sensor (cold & hot) and it appears to be OK.
However, with the relay connected i cant get any action from the fan by trying to earth 'E'.
I think the relay may have been fried when i played around with the old battery,....jump starting & all. Sad
5Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Mon Apr 06, 2015 5:11 am
do the "bridge"   but use a short piece of wire of small diameter (.25 mm ?) to join the two connection points
this will act as a fuseable link should anything happen in the future
good luck
6Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Mon Apr 06, 2015 6:40 am
Oliveri
Oliveri
will do, thanks Charlie.
7Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Tue Apr 07, 2015 12:56 am
@Oliveri wrote:......
EME don't appear to have any. You can buy one from Munichmotorcycles.com.au in Perth if you're in a hurry (they put it in an overnight bag for $10) but they're pretty pricey. Last time I looked I think they were well over AU$150 but Motorbins in the UK have them for around ½ that price incl frt I think???
  Temperature Relay Austra12    Fuel:  95 Octane
8Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Tue Apr 07, 2015 3:35 am
Oliveri
Oliveri
Ok, so I created a 'bridge' with a small piece of wire as per charlie's suggestion.
But now the bike will not start my fuel pump is not running and the #6 fuse keeps blowing.
So it appears that the bridge i created is now blowing the #6 fuse that also controls the fuel pump and FI.
Removed my bridge, bike starts again & no blown fuses. 🇳🇴  Not sure why it didn't work. But it was worth a shot....
I just hope that there is no other underlying issue that will destroy a new relay once i get one....
9Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Tue Apr 07, 2015 5:46 am
ok ...if the bridge then makes other things fail ...one needs to look at the component side and see whats causing the problem
I suspect ...(but haven't looked at the images yet ) that here is a blown component ...possibly a diode that has failed causing this issue ...once they go you need to replace
ill have a look at what images and explanation I can find ...
back later
edit
blast cant find the image I thought I had
anybody with a pic of the component side ????
10Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Tue Apr 07, 2015 10:10 am
Oliveri, can you post a good close-up of the component side of that board?
Cheers mate
11Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Wed Apr 08, 2015 8:50 pm
Oliveri
Oliveri
Sorry for  the delay. Work gets in the way of the important stuff from time to time. Here is the image of the component side.
Temperature Relay Temp-Relay21
It's the connection between the 2 diodes (red arrows) that appears broken.
12Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Wed Apr 08, 2015 9:25 pm
Have you tested the two diodes by putting the meter across then reverse the leads to see if they only conduct in one direction. Looking at that circuit there is a fair possibility that one of them is short circuit.
13Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Fri Apr 10, 2015 4:22 am
T3CHNO1D
T3CHNO1D
Could also be the transistor connected to those diodes (3 diodes in all). Best way would be to un-solder one end of the 3 diodes to test each one isolated, and then test the transistor once one end of each diode is un-soldered.
Very simple circuit, easy to fix, all parts are still available, quad-comparator takes in signal and turns relay on/off depending upon signals. About $10-$15 in parts to replace everything but the relay.
14Back to top Go down   Temperature Relay Empty Re: Temperature Relay on Fri Apr 10, 2015 5:02 am
Oliveri
Oliveri
Thanks for all the helpful info guys. Today I went to a guy not far from me (Ray Peake - RJ's BMW Motorcycle Service) who had a spare relay, $40 problem solved.
I will keep the old one and will get the relevant diodes to fix it (when i'm really bored one day). 🤡
