1Back to top Go down   temperature relay Empty temperature relay on Mon May 11, 2015 12:57 pm
smoll1
Hi all
Am having a problem with trying to get the fan to operate on k100rs. I have bypassed relay and fan operates no problem. I have tested temperature probe on block and get right resistance reading. I also jumped across terminals and temperature light comes on.
If i earth out the violet and green, think colour is wire, the fan kicks in. I have changed over relay as had two lying around and still nothing.
Do you think both relays are duff?
This is driving me nuts:D:D
For info it is back together after rebuild so has never worked since it is back together.
Help
Smoll:D:D
2Back to top Go down   temperature relay Empty Re: temperature relay on Mon May 11, 2015 5:37 pm
Floyd had this problem not long ago, try looking here
3Back to top Go down   temperature relay Empty sensor on Tue May 12, 2015 4:08 am
smoll1
Thanks i wil go through what floyd was advised and see if i missed anything i will let u know how i get on. Im thinking might be sensor issue will check wiring again.
Thanks smoll
4Back to top Go down   temperature relay Empty Re: temperature relay on Tue May 12, 2015 5:54 am
it is not unknown that corrosion has set up in the temperature sensor connector (both the pins in the sensor ...and the socket  that connects to it )
keep this in mind
although the ecu side of the sensor might measure correctly it is no guarantee that the side of the sensor that goes to the temp relay unit is all good
if in doubt ...remove and clean the parts properly before dismissing the sensor as faulty ,,,or the temp relay switching unit for that matter
good luck !
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Otemperature relay Au-log10
5Back to top Go down   temperature relay Empty sensor on Tue May 12, 2015 3:29 pm
smoll1
i tested all wiring today all good. i tested temp sensor and cold it read 1800 ohms which appears wrong, is this right. I earthed out e pin with relay plugged in and started bike and fan came on. Earths are all good as is continuity of wiring. Does this appear to point to faulty temp sensor?
Smoll Very Happy Very Happy
6Back to top Go down   temperature relay Empty Re: temperature relay on Tue May 12, 2015 5:12 pm
have a look at the graph
temperature relay Water%20temperature
7Back to top Go down   temperature relay Empty sensor on Wed May 13, 2015 4:11 am
smoll1
Thanks i think sensor is faulty have ordered new one so fingers crossed thanks all
Will let u know if it works Very Happy:D
8Back to top Go down   temperature relay Empty sensor on Mon May 18, 2015 1:40 pm
smoll1
It works. After fitting a new temp sensor the fan kicked in no problem. I could feel the thermostat opening and it was very nerve racking waiting for fan to start.
Thanks for all the advice brilliant forum SmileVery Happy:D
9Back to top Go down   temperature relay Empty Re: temperature relay on Mon May 18, 2015 7:52 pm
@smoll1 wrote:It works. After fitting a new temp sensor the fan kicked in no problem. I could feel the thermostat opening and it was very nerve racking waiting for fan to start.
Great result.
Good people and advice here, as you have found out.
10Back to top Go down   temperature relay Empty Re: temperature relay on Tue May 19, 2015 5:52 am
a good result !!
happy riding to you
