1Back to top Go down   K75c Fork brace/Mudguard mount Empty K75c Fork brace/Mudguard mount Fri May 15, 2015 9:36 am
My nuts are stuck!!!  Mad the four holding the front mudguard and brace are all siezed solid and the heads are mush. I've soaked them for a week, tried the hammered in Torx bit and nothing moving. If I get the "hot spanner" (i.e. grinder) to them can anyone tell me if the '85 brace and guards will fit a '91 (I know where there's a set to be had).
K75c Fork brace/Mudguard mount Ir-log1188....May contain nuts!K75c Fork brace/Mudguard mount Ir-log11
K75RTP - 1994
2Back to top Go down   K75c Fork brace/Mudguard mount Empty Re: K75c Fork brace/Mudguard mount Fri May 15, 2015 9:44 am
In a word Will No. You may have to take the forks apart and use some heat, the alloy grows inside the hole and it seizes really hard. I ground the head of and hammered the remainder out
3Back to top Go down   K75c Fork brace/Mudguard mount Empty Re: K75c Fork brace/Mudguard mount Fri May 15, 2015 9:48 am
RicK G wrote:In a word Will No. You may have to take the forks apart and use some heat, the alloy grows inside the hole and it seizes really hard. I ground the head of and hammered the remainder out
Onya Rick G.!  I was afraid of that! if you can hammer them through I'm assuming they are shouldered and not threaded bolts. Correct?
K75RTP - 1994
4Back to top Go down   K75c Fork brace/Mudguard mount Empty Re: K75c Fork brace/Mudguard mount Fri May 15, 2015 10:29 am
They are long shank 6mm with a nut on the back, no thread in the hole. You only need to loosen them to get the guard off as the holes are slotted.
