1Back to top Go down   Grease fittings in center stand? Empty Grease fittings in center stand? Fri Sep 04, 2015 9:23 am
jkh
jkh
I have a 93 K75RT. I have a Grease fitting on the side stand - nice easy to grease then. Onvthe center stand there is only a little hole. Os this normal ør has the PO changed the center stand?
As the center stand is not retracting properly i though that i would put a Grease fitting in there. Can this be done without remowing the center stand mount?
2Back to top Go down   Grease fittings in center stand? Empty Re: Grease fittings in center stand? Fri Sep 04, 2015 10:37 am
Some interesting discussions on centre stands here
https://www.k100-forum.com/t8174-centre-stand
Grease fittings in center stand? Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 60K Km     ;BMW;  K1100RS Black 1996       ;BMW; K1 Blue 1990 25K Miles
3Back to top Go down   Grease fittings in center stand? Empty Re: Grease fittings in center stand? Fri Sep 04, 2015 12:09 pm
jkh
jkh
Seems like my center stand was born without grease fittings. Ihave no knowledge about mounting grease fittings but i guess that i have to cut a thread in the grease hole and screw in the fitting. Is this the way to do it?
'93 K75RT - Previous bikes: '53 AJS Matchless, a lot of 70'ties Honda sohc/4's and some MZ's
4Back to top Go down   Grease fittings in center stand? Empty Re: Grease fittings in center stand? Fri Sep 04, 2015 8:32 pm
jkh wrote:Seems like my center stand was born without grease fittings. Ihave no knowledge about mounting grease fittings but i guess that i have to cut a thread in the grease hole and screw in the fitting. Is this the way to do it?
Yes, but check that the grease nipples don't protrude past the inner size of the metal they are screwed into. Carefully file shorter and clean filings out thoroughly if they do.
