1 Faulty Rev Counter Thu Mar 24, 2016 9:38 pm
rob_gordon
I have K100RT (1987) which came with a faulty speedo and rev-counter. The speedo didn't work at all so I replaced the Impulse transmitter which fixed the speed issue. However, I am not sure how to go about fixing the rev counter. It works to an extend but reads about 1500 rpm too low. The needle seems to be way below the 'zero' when the bike off and sits at about the 'zero' level when the bike is running at idle. I wondered if anyone had a similar issue and whether I should be taking the instrument panel out and adjusting the needle or whether the issue may be at the pickup from the engine (not sure where the rev-counter picks up its signal. Any help greatly appreciated.
