Number of posts : 7903
There have been quite a few threads on vibrations.
Check out bar end weights, they do make quite a difference. Make sure you have them in place.
Check out your throttle mechanism that is clean and well lubed so it doesn't need much effort. Consider one of those devices that allow you to keep throttle open without gripping it tightly.
Make sure grips are good and not too old.
Make sure front wheel is well balanced and running true.
Are you happy with the angles of the levers and handlebar angle/position. Lots fit bar risers.
After that its down to making sure engine is right as in injectors, balanced etc.
1971 Yamaha 125 YAS-1
