1 problem mounting radial tyre on K100 front wheel Fri May 27, 2016 11:40 am
Beamer
Hi,
has anyone encountered problems getting radial tyres to seat on BMW cast wheels?
I've spent the morning trying to manually fit a Battleaxe radial tyre and it won't sit properly. It's impossible to get any air into it to inflate it enough to get it to sit on the rim.
The tyre seems unusually tight and there a several places where it is not making enough contact with the rim and this is making it impossible to inflate.
There is an added problem that there are a couple of dents in the bead of the tyre. I don't know what the origin of this is but it must take some forcing to deform the bead of the tyre. This may be contributing to the leak problem. I should probably have refused to take it. In any case I'll have to take it back now anyway.
Also the tyre tends to buckle in a couple of places, being less rigid than a cross-ply construction. It's the first time I've tried mounting a radial on these bikes so I don't know whether this is also an indication of a problem.
Are radial tyres more difficult to mount on these rims?
Anyone any experience of mounting these radial tyres themselves?
