1Back to top Go down   Fuel pump not priming Empty Fuel pump not priming Fri Sep 15, 2017 6:50 pm
audibob
audibob
Hi all,
my k100 fuel pump does not prime when the ignition is switched on.
Any ideas anyone ?
Pump output is good and she pulls all the way to the redline.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   Fuel pump not priming Empty Re: Fuel pump not priming Fri Sep 15, 2017 7:03 pm
audibob wrote:my k100 fuel pump does not prime when the ignition is switched on.
That's normal on a Jetronic equipped model......the fuel pump starts when
you hit the start button.
3Back to top Go down   Fuel pump not priming Empty fuel pump not priming Fri Sep 15, 2017 7:35 pm
audibob
audibob
Thanks for the info Inge.
I assumed the pump should prime when the key is turned.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
4Back to top Go down   Fuel pump not priming Empty Re: Fuel pump not priming Fri Sep 15, 2017 8:18 pm
It only pumps when the engine is turning. The 4 valve Ks do prime the pump for a few seconds when the ignition is turned on though.
5Back to top Go down   Fuel pump not priming Empty Fuel pump not priming Sat Sep 16, 2017 9:10 am
audibob
audibob
The reason for this post was during my recent 1100 TB swap I checked the fuel pressure .
With the gauge in place I switched the ignition on and before I hit the starter button,  I heard the pump run  and it primed the system .
That surprised me to say the least as I have never heard it prime before or since .
If my pump is not supposed to prime, how did this happen ?
Comical answers will be expected and duly accepted
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
6Back to top Go down   Fuel pump not priming Empty Re: Fuel pump not priming Sat Sep 16, 2017 9:22 am
Obviously the 1100 TBs gave it ideas above its station before it woke up to itself.
(Ask and Ye shall receive.). Razz
7Back to top Go down   Fuel pump not priming Empty fuel pump not priming Sat Sep 16, 2017 10:18 am
audibob
audibob
Thanks Bill..
You could be right ...
But I know what I heard... affraid
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
8Back to top Go down   Fuel pump not priming Empty Re: Fuel pump not priming Sat Sep 16, 2017 1:57 pm
Is the harness original, without any "owner modifications"? Anything is possible if modifications have been performed on the wiring.
9Back to top Go down   Fuel pump not priming Empty fuel pump not priming Sat Sep 16, 2017 6:33 pm
audibob
audibob
Hi Robmack,
The only modifications to the wiring I saw was  bullet type crimped  connectors to the ignition switch cable at the
rear of the tank instead of the normal multi block type.
Not sure why that was done.
Apart from that the loom looked okay.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
10Back to top Go down   Fuel pump not priming Empty Re: Fuel pump not priming Sun Sep 17, 2017 2:25 am
uhoh7
uhoh7
Sry to piggyback, but I have a similar thing.
I removed the tank on my two week old 1985 K100RS. I was changing coolant and dealing with weird wiring. I also was starting to clean a bit around and under the throttle bodies. The caps on the bodies were bad or missing, so I replaced them. I bypassed the BMU. I attempted but did not succeed with pin 7 on the flasher unit, but I went around it to get the non-working side blinking.
Put all back together. Power switch, lights, turn signals all work.
When I hit the starter, I hear the fuel pump, but engine does not turn over.
Did I dislodge a wire under the bodies, or something?
TY all Smile
