1 What have I done!! Wed 22 Feb 2017, 10:10
wilbo
So I fired up the log burner in my garage, replaced a strip light with a brighter LED one and persuaded my dad to spend the afternoon with me removing the frame from the engine, 3 hrs later we were all done and I was surprised we did not have more issues. I took multiple photos as I went along so I know what connector goes where and we completed a good afternoons work.
I am getting the frame blasted at the weekend as I can get it done in work on the weekend , and I shall prime it the same evening and then respray it black over the coming week. Engine wise as it is 34 years old I have a new water/oil pump to fit, will pull the alternator/starter motor and rebuild brushes etc. I shall also remove and check all splines and see what the condition of the clutch is like. Injectors are going away for servicing/cleaning.
What I would like is if anyone would like to shout up any other jobs I should do while I have the bike in pieces, it is a 1983 model and I have read about sprag clutch and splines etc but all advice shall be gratefully taken on board.
Pre strip down so I can remember what it looked like!
Starting to remove bodywork
And finally all removed!
Current Stable
1983 BMW K100
1996 BMW R100RT
2009 Honda CBF1000
2003 Aprilia RS250
1996 Kawasaki GPZ500s
1955 James Colonel 225cc
