1Back to top Go down   K1200 gas cap mod on my K100 cafe Empty K1200 gas cap mod on my K100 cafe Fri Jul 19, 2019 9:36 pm
MikeisonTV
MikeisonTV
So I’m planning on adding this k1200 gas cap to my k100 cafe tank. I’ll need to do some notching but love the look. Anyone done this yet?
Also, I have the ignition switch and would love to use 1 key. This will also free up an ignition switch/ gas cap combo for someone in need.
My electrical ninjas...will this be possible?
MikeisonTV
MikeisonTV
3Back to top Go down   K1200 gas cap mod on my K100 cafe Empty Re: K1200 gas cap mod on my K100 cafe Fri Jul 19, 2019 10:07 pm
I assume you are going to notch the tank mounting ring to get the cap level with the tank. Would it not be better to machine the mounting stubs down.  Then you could redrill the mounting ring to suit. It's hard to tell from your picture whether it's wide enough to do this.
4Back to top Go down   K1200 gas cap mod on my K100 cafe Empty Re: K1200 gas cap mod on my K100 cafe Fri Jul 19, 2019 10:28 pm
If you have the K1200 ignition switch then I'm sure it would be fairly easy to graft it to the antique K.
Do you have a wiring diagram for the K1200 ignition?
What are the colors of the wires for the K12 ignition switch?  Bosch is pretty good at standardizing wiring colors.
MikeisonTV
MikeisonTV
MartinW wrote:I assume you are going to notch the tank mounting ring to get the cap level with the tank. Would it not be better to machine the mounting stubs down.  Then you could redrill the mounting ring to suit. It's hard to tell from your picture whether it's wide enough to do this.
This is a much more logical and less invasive idea! I’ll probably need to use the bottom half of my original gas cap as this is the k1200’s:
K1200 gas cap mod on my K100 cafe B9563c10
MikeisonTV
MikeisonTV
duck wrote:If you have the K1200 ignition switch then I'm sure it would be fairly easy to graft it to the antique K.
Duck you’re always game to help out! I’m grateful for your K Yoda like knowledge.
K1200 gas cap mod on my K100 cafe C997c210
What model/year K1200?
MikeisonTV
MikeisonTV
duck wrote:What model/year K
They aren’t sure...I got from a parts house.
MikeisonTV
MikeisonTV
After MartinW’s idea I found this big ass rubber grommet to sandwich inbetween the soon to be shaved Cap and tank.
Seems a lot easier than buying that other plastic tank and cutting it up.
K1200 gas cap mod on my K100 cafe F3513010
