1Back to top Go down   Fuel tank leak Empty Fuel tank leak Wed 21 Aug - 16:02
Porto
Porto
My tank has deteriated underneath where sender is mounted on the inside. It’s a large hole with a few pin holes around. I’m certain how to proceed and am worried that other tanks will have same problem. Can any one advise or help?Fuel tank leak B8592d10
Fuel tank leak 6eb3a110Fuel tank leak B8592d10
https://gpleather.com
2Back to top Go down   Fuel tank leak Empty Re: Fuel tank leak Wed 21 Aug - 16:34
hi porto ,
many have experienced the same
if you can find a fabricator , that will work by welding a fuel tank , many wont look at it hands down , but there are some out there
usually a plate welded to cover the hole will work fine , BUT , be aware that up the side of the tank in the same area is another likely weak point , where oxidisation has thinned out the aluminium skin , as you have seen near the fuel pump . its a low point in the tank where water will sit and oxidise away un-noticed for years
whilst its apart ...probe in that area and get it done at the same time
good luck
3Back to top Go down   Fuel tank leak Empty Re: Fuel tank leak Wed 21 Aug - 17:13
Porto
Porto
Thanks Charlie,
That all makes sense now mate. I will start looking for a welder now. I was worried I would have to try and apoxi it up .
4Back to top Go down   Fuel tank leak Empty Re: Fuel tank leak Wed 21 Aug - 17:19
There a welder up here in Brisbane  which did mine  but that wont help unless your posting it up
I had 8  holes in mine and then he pressure tested it  for me
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
5Back to top Go down   Fuel tank leak Empty Re: Fuel tank leak Wed 21 Aug - 20:21
I agree with Charlie - go for a weld repair rather than epoxy.
I've had K bike tank leaks welded up in both Sydney & Maitland. Might be worth seeking out marine fabricators who work with aluminium all the time.
6Back to top Go down   Fuel tank leak Empty Re: Fuel tank leak Tue 27 Aug - 18:04
Porto
Porto
Thanks for the advise fellas. I’ve filled it with an epoxy to hopefully keep me going till I find a welder near me. I’m hoping it seals it or at least plugs it so it’s just seaping a little. I can’t cope having it off the road. I’ll start checking marine places for tank welders.
