1Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Pinion Oil Seal Ring Tool Required Sat Jan 25, 2020 5:04 pm
When checking the spline lube situation I discovered I've a final drive pinion oil seal leak. Does anybody local either have the pinion oil seal ring tool for sale, hire or loan. Or failing that does anybody know where the tool  can be bought locally. I did think about making one but due to the force required I didn't want to make the situation worse by stuffing up the ring.
Read this post and those following,Martin, for alternative tool ideas and outcomes.
3Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Sat Jan 25, 2020 10:15 pm
Laitch I've already tried to source spindle nut sockets online but they come up as a US item. I've taken all the measurements and it might be a case of manufacturing one. Off to the Trades Guild on Tuesday and I'll look into making one. Made a static wheel balancer on Friday because I couldn't get my rear tyre balanced locally.
4Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Sun Jan 26, 2020 12:01 am
MartinW wrote:I've taken all the measurements and it might be a case of manufacturing one. Off to the Trades Guild on Tuesday and I'll look into making one.
At that link there was a description of the successful use of a socket made from electrical conduit then welded to a conventional socket. Did you read that one?
5Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Sun Jan 26, 2020 12:15 am
Thanks Laitch  it's given me a few ideas, and I'm sure between myself and the Guilds brains trust we can cobble together something.
The spring clip number 14 I think that retains the drive shaft is no longer functioning, and I'm not sure whether running without it is a good idea. They are still available.
Regards Martin. Pinion Oil Seal Ring Tool Required Drive_12
I used a 42mm 3/4 drive socket and cut some tangs on it but have since had to return it to a socket to do wheel bearings on my X5
Thanks Rick what's your thoughts on running without the spring clip.
Don't run without it because the bearing shaft can and will migrate. I've not seen it happen on a K, but I have seen it happen on a Guzzi.
10Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Sun Jan 26, 2020 5:21 am
caveman
caveman
I ground slots, tangs in a piece of an old fork tube to fit the nut then welded a cheap socket in the other end. It worked great and caused no carnage to drive unit.
11Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Sun Jan 26, 2020 6:55 am
MartinW wrote:Thanks Rick what's your thoughts on running without the spring clip.
Don't
12Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Sun Jan 26, 2020 3:28 pm
Pinion Oil Seal Ring Tool Required 112350
13Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Mon Jan 27, 2020 5:15 pm
Pretty sure Paul  aka Brickman has the tool your looking for
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
14Back to top Go down   Pinion Oil Seal Ring Tool Required Empty Re: Pinion Oil Seal Ring Tool Required Mon Jan 27, 2020 10:02 pm
Matt I have started making one and hopefully should have it done on Friday. Parts from Munich should be here tomorrow, They couldn't supply the boot so I'll clean and treat the old one. How's progress on the resurrection going?
