1Back to top Go down   Tight Valves Empty Tight Valves Sat Jun 20, 2020 6:11 pm
zaubertuba
zaubertuba
Just checked my valve clearances.  One intake is a little tight and ALL the exhaust valves are tight--it seems very tight:
I1 .15
I2 .12
I3 .15
I4 .15
E1 .20
E2 .12
E3 .15
E4 .15
Bad enough to warrant reshimming?
1985 K100RS
2Back to top Go down   Tight Valves Empty Re: Tight Valves Sat Jun 20, 2020 6:13 pm
Yes. All valve clearances should be within spec.
3Back to top Go down   Tight Valves Empty Re: Tight Valves Sat Jun 20, 2020 6:28 pm
moriarti
moriarti
Reshimming might help with MPG as well Very Happy
4Back to top Go down   Tight Valves Empty Re: Tight Valves Sat Jun 20, 2020 7:04 pm
zaubertuba
zaubertuba
moriarti wrote:Reshimming might help with MPG as well Very Happy
Heh it might. Wink
So since they seem to get tighter is it fair to assume I should shim towards the looser side of the specs?
1985 K100RS
5Back to top Go down   Tight Valves Empty Re: Tight Valves Sat Jun 20, 2020 7:11 pm
moriarti
moriarti
Correct,shims/tappets settings reduce with heat,so a little give is ok,hence the max/minimum numbers .Tight settings,valve not closing/seating fully,means,loss of power hence poor mpg
Last edited by moriarti on Sat Jun 20, 2020 7:18 pm; edited 1 time in total (Reason for editing : brain in slow mo)
6Back to top Go down   Tight Valves Empty Re: Tight Valves Sat Jun 20, 2020 8:01 pm
moriarti
moriarti
Also do a compression test first cold and one with oil added then again after valves done to give you a comparison Very Happy
7Back to top Go down   Tight Valves Empty Re: Tight Valves Sun Jun 21, 2020 12:18 am
Tight exhaust clearances cause burnt valves because good contact to dissipate heat can't be made when the valves close.  The hotter exhaust valves also expand more than the cooler intake valves reducing the clearance more as the engine gets hot.  Shim them to the wide end of the spec.
Intake valves, on the other hand, are cooled by the incoming fuel/air mix.  Tight valve clearances on intake valves help the engine breathe better.  It's no big deal if they are at the tight end of the spec.  Just make sure they are still in spec.
I try to get the clearances as close to the same as possible, it makes for a smoother idle.
8Back to top Go down   Tight Valves Empty Re: Tight Valves Sat Aug 22, 2020 3:40 pm
zaubertuba
zaubertuba
Just to follow-up.  Got my valves from Cycle-re-Cycle, was able to change them pretty easily using the Screwdriver/Compressed Air method. Pretty slick!
Pretty amazing difference. Bike idles much better, and throttle response is better/smoother throughout!
1985 K100RS
