1Back to top Go down   Exit (stage) Left in 100yds Empty Exit (stage) Left in 100yds Sun Jun 03, 2012 6:30 pm
Terry Dactyl
Terry Dactyl
Hello all. Busy getting on with getting on with the K. Done the brakes (as mentioned elsewhere), changed all the oils now (engine, gearbox, final drive), and ALL were B L A C K! Not had chance to get out on it yet, but am sure the changes can only do it some good! (I was begining to get annoyed at the thing finding false neutrals all over the place, up and down the gear box - downright dangerous actually). Just wanted to ask y'all, 'has anyone managed to mount a sat nav to a K100RS without any major issues, and if so how?' (a few pics would be nice). Plus where did you put the power supply?
2Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Sun Jun 03, 2012 7:20 pm
The best place to get power for a GPS is the feed to the front parking light.
About the mounting, just use the Google search engine on the forum and you will see all kind of examples.
Exit (stage) Left in 100yds Frog15Exit (stage) Left in 100yds Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Mon Jun 04, 2012 12:02 am
Try Satnav for K75 in the search section...good luck.
4Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Fri Jun 08, 2012 5:56 pm
If all the oils were black it could be the previous person who changed the oil used either MoS2 or Graphite suspension in the oil that would account for the gearbox and final drive oil being black.
5Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Sat Jun 09, 2012 1:55 am
club_c
club_c
Terry Dactyl wrote:Hello all. Busy getting on with getting on with the K. Done the brakes (as mentioned elsewhere), changed all the oils now (engine, gearbox, final drive), and ALL were B L A C K! Not had chance to get out on it yet, but am sure the changes can only do it some good! (I was begining to get annoyed at the thing finding false neutrals all over the place, up and down the gear box - downright dangerous actually). Just wanted to ask y'all, 'has anyone managed to mount a sat nav to a K100RS without any major issues, and if so how?' (a few pics would be nice). Plus where did you put the power supply?
I just bought some supplies from RAM Mounts in USA. They just arrived yesterday. You buy the components as required for your bike application and device application. I haven't tried to fit them yet, but it looks simple enough. Check the website and let me know if you need part numbers.
1988 K100RS SE VIN 01477554
6Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Thu Sep 10, 2020 9:17 am
Zara
Zara
Crazy Frog wrote:The best place to get power for a GPS is the feed to the front parking light.
Will that not affect the bulb monitoring unit?
7Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Thu Sep 10, 2020 7:31 pm
No. Contrary to what the diagram would have you believe, the pilot light is not monitored.
8Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Fri Sep 11, 2020 3:39 am
tinyspuds
tinyspuds
As I use my satnav (with clock) on all journeys I didn’t really need the (constant drain) dash clock so I cut that feed in the relay box and use it for the gps. Now I can use the gps before powering up anything else. Works for me.
9Back to top Go down   Exit (stage) Left in 100yds Empty Re: Exit (stage) Left in 100yds Fri Sep 11, 2020 5:43 am
Zara
Zara
Dai wrote:No. Contrary to what the diagram would have you believe, the pilot light is not monitored.
Thank you, Dai
