ABS removal. Sun Dec 20, 2020 9:15 pm
![MartinW](https://2img.net/u/4211/29/48/93/avatars/5142-60.png)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
We had previously tried to get Bruce's ABS system working. Fault codes had indicated a computer and a relay problem. Another computer and a set of relays failed to remedy the faults. So we determined that a strip down to standard was probably the way to go. The old lines were OEM rubber and the brake fluid well past it's replacement date. New lines were obtained locally from Aussie Automotive Services Lawnton. Sean has done brake lines for me previously and if not busy will do them on the spot and always does a great job. Bruce and I fronted up with an old front brake line for comparison but no rear line. Sean got straight on to the job using my bike to compare with Bruce's ABS system. A few methods and routes were compared until we came up with something that worked and looked good. The new rear line was made up and then he copied the old front line which was a lot more straight forward. All up he spent a good hour working it all out. Total cost for front and rear lines plus copper washers was $150.00. I highly recommend Sean and Aussie Auto Service they are always helpful and have solved a few problems for me over the years.
The next day Bruce fronted up with his bike and we commenced the change over. In order to do the job the seat, fuel tank, side covers, battery, rear half of the front mudguard needs to be removed and the tool tray swung out of the way. We started on the rear first removing the rear modulator hoses and disconnecting the wiring from the plug under the seat. The wiring needs a bit of wrangling to get it out. After removing the retaining bolts the modulator was removed. The new hose fitted perfectly but when we tried to bleed the system it wouldn't pump up. We were using my Nescafe bleeder and we even tried manual bleeding. The rear master cylinder was found not to be working. The rear master cylinder was removed in the hope of cleaning it out, and even with all the crap cleaned out it was never going to work. The cups were found to be scored and the cylinder will require honing and a new kit. I pulled my spare OEM one out of stock cleaned it out and lubed it with fresh fluid and installed it. It immediately bled up and we had a good pedal.
Next onto the front hose the old ones were disconnected and the new hose fitted. A minor problem occurred with a leak at the master cylinder banjo bolt. Replacing the copper washers didn't cure the leak but replacing the banjo bolt and washers cured it. The new hose fitted perfectly. The system bled up quickly and easily. The bike on the side stand and the bars on left lock for the bleeding. The front modulator hoses were then removed and once the electrical connector under the tank was disconnected the modulator was removed. All that we were left with was the removal of the modulator support frame which requires the removal of the battery tray and the piping. After looking at trying to remove the piping intact we decided that it wasn't worth the effort. The piping was blown through to try and reduce spillage, but little fluid was evident. In order to get at one of the connection the bolts on the ignition module need to be removed and the module pushed back. The piping was cut into workable lengths with a good set of side cutters and pulled through.
The front guard was then replaced along with the battery tray , battery, tank, seat, and side covers. There are a few more little brackets and clips and wheel sensors that I've left Bruce to deal with. All up the job took 5 hours. We still have Paul's LT's ABS to strip which should go a lot quicker as we know where to locate things and hopefully his master cylinder is OK. I'd like to thank Sean for supplying the hoses and Bruce for his assistance. Bruce will send me a couple of pictures which I'll then post. We will probably do more and better pictures when we do Paul's LT.
![ABS removal. Brake_10](https://i.servimg.com/u/f39/19/69/46/61/brake_10.jpg)
![ABS removal. Aussie11](https://i.servimg.com/u/f39/19/69/46/61/aussie11.jpg)
