1Back to top Go down   Front crank seal dimensions Empty Front crank seal dimensions Wed Mar 31, 2021 1:50 pm
nino
Hello, anybody to send front seal dimensions. That seal behind hall sensor slightly leaks, Thanks
2Back to top Go down   Front crank seal dimensions Empty Re: Front crank seal dimensions Wed Mar 31, 2021 2:05 pm
nino wrote:Hello, anybody to send front seal dimensions. That seal behind hall sensor slightly leaks, Thanks
You only have to look it up in realoem.com or other online site. BMW often shows dimensions for seals and for bearings. It's current OEM part number 11 14 7 654 531 and measures 52x36x7.
3Back to top Go down   Front crank seal dimensions Empty Re: Front crank seal dimensions Wed Mar 31, 2021 3:39 pm
Also, buy an original seal.
