Bonzo
Bonzo
Is there any special equipment needed regarding the ABS?
I've bought some Venhill braided lines from Motobins with the plan to get them fitted by a local mechanic (I wouldn't trust myself with the job). He said he cant do it properly as he cant bleed the ABS without the special 'plug' that the old dealers used on these models. He reckons he wouldn't be able to get all the air out.
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
Can you operate 11, 13, and 14mm spanners? Yes? then go ahead and change the lines yourself. The hardest part of the job is making sure not to get the DOT 4 on the paint work. (I keep a spray bottle of water and a towel close at hand to administer first aid when, not if, I spill some brake fluid.)
Bleeding is a test of your right/left hand coordination. If you can slowly slap a table top with alternating hands you are well qualified for the job of bleeding the system.
The job shouldn't take more than 2 hours at worst. Take the money you save by doing it yourself and buy fuel for the bike and a couple pints to celebrate.
mike d
As mentioned, no need for any special kit to bleed the brakes. maybe the delaer was thinking about the iABS setup as fitted to the R1150 and K series post 2001. They do need to have the module exercised.
Bleed the modules first then the wheel calipers.
Mike
Bonzo
Bonzo
You guys have more confidence in my abilities than I do for sure. I struggle bleeding the brakes on my mountain bike  Embarassed
Even the Clymer manual tells me not to touch it and hand it over to an expensive BMW technician  scratch
I suspect the Clymer advice has been edited by their liability legal team.
On the ABS1 bikes the bleeding is straightforward, the only difference being that there are two extra bleeders on the ABS modulators that need to be addressed.
Open, squeeze, close, release. A 6mm hose guides the old fluid to a half full 4 liter jug of water. The water dilutes the old fluid so it isn't as corrosive and, more importantly, makes it more stable so it doesn't tip over and spill the fluid al over the place.
Bonzo
Bonzo
Thanks for the wisdom & encouragement guys.
I'm gonna give it a go  Replacing Brake Lines (on ABS Model)? 112350
Bonzo
Bonzo
By the way, do you guys use a hand vacuum pump to pull the old fluid through?
I do use a vacuum bleeder but they are easy to do without one.
You need a Nescafe bleeder.
Replacing Brake Lines (on ABS Model)? Brake_11
caveman
caveman
May I suggest before taking the lines off, bleed some fluid through to make sure your master cylinders are working properly and the small rear hole is open (returning freely to allow make up fluid). If the cylinders have not been bled in a while they may stick in the bore when going full stroke so go 1/2, 3/4 and work your way up to full stroke. Good luck!
I used a vacuum bleeder, but found that it sucked air in around the threads of the bleeder fitting. This is no big deal, but the bubbles that were constantly coming through the hose made me question if I had bled all the air out. Now I just use the tried and true old school method of open. squeeze, close, release.
Bonzo
Bonzo
MartinW wrote:You need a Nescafe bleeder.
Darn it! I just bought two jars of Carte Noire  Shocked
I use the earlier Vegemite model.
So waht's wrong with the Marmite version?
I use the chutney version.
If it's made in Ind*a .... oh, sh*t.  No wonder it takes so long.
Bonzo
Bonzo
Well, much to my surprise this actually went ok until.... ah we'll get to that.
Did the rear first figuring it would be easier as everything is in close proximity and all went well.
Started on the front. The upper was a bit of a pain as the MC to steel mod pipe is buried under wiring under the tank, but we got there with a bit of cursing.
The downside is the front lowers (2 x splitter to calipers) in the Venhill 'kit' from Motobins come with male - banjo, whereas my originals are banjo to banjos. I thought I'd get away with it, but the new lines are just a tad too short (without putting a 90 degree kink in the line).
I'm gonna have to get in touch with Motobins, but its a bit of a pain as I wanted to sort it this bank holiday weekend.
Replacing Brake Lines (on ABS Model)? Img_2026
Replacing Brake Lines (on ABS Model)? Img_2027
Replacing Brake Lines (on ABS Model)? Img_2028
Bonzo
Bonzo
on the plus side, it did mean I got to watch one of the best MotoGP races in ages  cheers
Here's the line that doesn't quite fit.. (assuming I have the original splitter??)
Replacing Brake Lines (on ABS Model)? Img_2029
Replacing Brake Lines (on ABS Model)? Img_2030
gorio
Maybe a silly question but what happens if you try the banjo end up at the splitter?
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
1982 Kawasaki 750GPZ
1975 Norton 850 Commando
Bonzo
Bonzo
gorio wrote:Maybe a silly question but what happens if you try the banjo end up at the splitter?
Not a silly question at all gorio, alas the angle is too tight, the length too short and if the male union went into the caliper it would be a wheel out job to give enough clearance.
*EDIT* Sorry, I mean caliper off job rather than wheel out.  Embarassed
I think you'll find that the male end does have to go in the caliper. Just take the caliper off the fork leg and wind the hose in, then tweak it up with the caliper back on the bike.
Bonzo
Bonzo
I'll try it Dai, but I think its too tight, as in a kink in the line to get the banjo in at the splitter.
I'll report back tomorrow  Replacing Brake Lines (on ABS Model)? 112350
Bonzo
Bonzo
Yeah, the male straight out of the caliper is on the rim.
gorio
Bonzo wrote:Yeah, the male straight out of the caliper is on the rim.
Just checked the three bikes here and they are all banjo at the caliper. Was worth a try!
In looking at the photos the crimp part connecting the fitting to the tubing part seem longer then the old one so that could make the difference. That is me assuming most the length of the black heat shrink is over what is ridged? It is such a short line there isn't much wiggle room on it.
I am sure Motobins will sort it out as they likely sell hundreds of those a year.
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
Bonzo
Bonzo
As an update to this,
I contacted Motobins who confirmed that they only supply a male - banjo fitting for the front lowers, and have now amended their site to state that. They offered me a refund if I returned them, but I sourced a couple of Venhill 75 degree banjos to replace the males and they fit a treat. I informed Motobins that I wouldn't need to return them and they kindly fired me a tenner 'hassle' refund  Replacing Brake Lines (on ABS Model)? 112350
I then noticed that the new Venhill banjos are a tad (not a very scientific measurement as I don't have a vernier guage) shallower than the originals, effectively lengthening the union bolts. So I ordered some more Venhill domes bolts, this time 1mm pitch instead of 1.25mm along with new washers.
All good? Haha. Sadly, I cant get the junction with the splitter to seal properly  Replacing Brake Lines (on ABS Model)? 61740. I love filling the system and then finding a leak  Replacing Brake Lines (on ABS Model)? 259495.
I'm convinced it's the alloy 3-way splitter that is showing the ravages of 31 years of corrosion. I searched and found our friend The Mighty Gryphon's comments (#3) on the Motobrick site and took his advice with a strip of fine wet & dry. Here's the splitter after after a clean up. Still not perfect, but I'm hoping I can get a seal once the new bonded sealing washers turn up. The last pic is the troublesome fitting.
Replacing Brake Lines (on ABS Model)? Img_2031
Replacing Brake Lines (on ABS Model)? Img_2032
 Replacing Brake Lines (on ABS Model)? Img_2033
Replacing Brake Lines (on ABS Model)? Img_2034
A couple of 'What would you do?' questions.
What sort of torque should I go with these? Venhill suggests 15Nm on their domed head bolts. That might be ok on the calipers, but I don't know if that's a bit too much on this fragile looking splitter. The clymer manual (oe lines and bolts) says only 6-8Nm.
Do new copper washers need annealing before fitment, or just pop 'em on and tighten?
Cheers.
moriarti
moriarti
Bonzo ,Only used copper washers need to be ANNEALED. You might get better sealing with Dowty washers, than copper Very Happy
Bonzo
Bonzo
moriarti wrote:Bonzo ,Only used copper washers need to be ANNEALED. You might get better sealing with Dowty washers, than copper Very Happy
Thanks moriarti, I thought it was only when re-using, but wanted a bit of confirmation in the hope of avoiding further leaks (and curses).
Yeah, dowty washers ordered earlier today  Replacing Brake Lines (on ABS Model)? 112350
