1Back to top Go down   K100 additional electronics box  Empty K100 additional electronics box Thu May 13, 2021 7:07 am
snowy
snowy
Some advice please, i have an additional box of electronics located in the tail tidy on my K100 trike, has the same sort of connector as the under seat/tool kit holder, can i remove without causing many and varied electrical problems with the trike.
After it has passed it's MOT tomorrow Friday 14/5/21 i will be looking to get it resprayed, been promising to do that for 4 years now.
Any and all advice much appreciated, Snowy
Do you have ABS fitted because it could be the control box.  That's where it is on mine.
TacKler wrote:Do you have ABS fitted because it could be the control box.  That's where it is on mine.
+1 ABS brain.
4Back to top Go down   K100 additional electronics box  Empty additional 'brain' in tail tidy Fri May 14, 2021 1:51 pm
snowy
snowy
Hi all, thanks for that, no abs fitted so i am going to assume it is redundant and can be removed.
Will follow the harness then individual cables back into the main loom checking against the wiring diagram.
cheers and beers
Snowy
