1985 K100RS Fork Shims Fri Apr 01, 2022 2:06 am
clappy
![clappy](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
Hi,
When I disassembled the forks there was a shim (31 42 1 458 327) on each seal below the fork cup.
Is that the correct order? Seal, shim, cup? Or is it shim, seal, cup? Are the shims even necessary?
Also, there's no circlip in the top near where the seal goes on an '85, right?
ThanksWhen I disassembled the forks there was a shim (31 42 1 458 327) on each seal below the fork cup.
