fishboy316
fishboy316
So I took the key out of the ignition and when put back in could'nt get it to go to the second "click". Took 15 minutes to get it to the run position.Shocked
Any ideas?
moriarti
moriarti
Hi Bill sounds like the pin is jamming, you can try WD40,or PULL CYLINDER out and do a full cleanup,Good luck with it Very Happy Very Happy
fishboy316
fishboy316
Thanks for the reply. I will give  it a go!
Ignition switch cleaning instructions. It's likely the entire mechanism in yours will need it eventually anyway.
fishboy316
fishboy316
Thanks for the help. I did get it going with a few squirts of Electronics cleaner and some spray electronics  lube.
Looking at the Helpful Instructions for cleaning the switch I thinkI will do a full clean soon.
Thanks  again for the help
