1Back to top Go down   rebuild electrical system Empty rebuild electrical system Mon Sep 26, 2022 1:17 pm
Rochen
Rochen
Hello everyone,
Soon I will do a rebuild of the electrical system to be able to clean it up in the best possible way. I had thought about automotive cloth tape to wrap all the wiring, but I have a question. What type of electrical connector to use for the wiring terminals? unify and use in all the same? For lights and turn signals other? There are many connectors on the market and I don't know which one to choose.
Thank you very much!
2Back to top Go down   rebuild electrical system Empty Re: rebuild electrical system Mon Sep 26, 2022 10:19 pm
Use AMP Superseal, Deutsch, Metro-pack or Sumitomo waterproof automotive connectors everywhere possible. See https://easternbeaver.com/Main/Elec__Products/Connectors/connectors.html.
3Back to top Go down   rebuild electrical system Empty Re: rebuild electrical system Tue Sep 27, 2022 6:06 am
Rochen
Rochen
Thank you for your tips
4Back to top Go down   rebuild electrical system Empty Re: rebuild electrical system Wed Sep 28, 2022 4:35 pm
You need two-pin Junior Timer connectors for the fuel injectors and the temperature sensor and a three-pin (or four-pin) Junior Timer connector for the throttle position sensor. You can not get the five-pin connector for the Hall Effect sensors, so you will need to cut that off and solder new wires to the original ones. (Yes, I make my own wiring harnesses too).
5Back to top Go down   rebuild electrical system Empty Re: rebuild electrical system Thu Sep 29, 2022 11:43 am
Rochen
Rochen
Thank you Dai!  cheers
