Go to page : 1, 2  Next
Well , for a couple of months now i have been busy yet again .
it all started with a surprise phone call from our mate Nigel.
quite unexpectedly i found my way towards Balina to meet again and a poor old K100 resting in a shed
As Nigel explained , he was pretty much time poor to give the old girl some much needed TLC ,
So loaded up, had some brunch, and headed back to the highlands with a heap of parts and "Black Betty" in tow .
Krikey ...another one followed me home  20230410
for Nigel , sad to see her go, but needed to be done .
Unpacking the tin box the next day , i had a fair amount of gubbins to sort through , with some fairly helpful bits and pieces to store or use on the repairs - service .
Krikey ...another one followed me home  20230413
some pics ...before ....
Krikey ...another one followed me home  20230411
Krikey ...another one followed me home  20230412
Krikey ...another one followed me home  20230414
Krikey ...another one followed me home  20230415
the repairs
as you will have noticed the tank had a sizeable leak at a couple of places along the left seam
over time this had leaked stale fuel all over the head and everything around that area ...hmmm
as usual, internally the tank was dried out crud flakes all throughout
withdrawing the internals
Krikey ...another one followed me home  20230416
recovered the sender , as usual , a lot of work but seems successful
Krikey ...another one followed me home  20230417
found a fuel cap that would work and a cylinder to match needing re-keying  , but the internal cam , tongue and return spring
 needed help , fortunately Frank in blighty was able to help out with a couple of parts and after a few weeks we have a functioning
tank lid , modified , charlie style .
Krikey ...another one followed me home  20230513
new fuel pump , filter and internal lines assembled and ready to go into the "good to use tank " after i get it painted , taking quite a while to clean off glues etc just yesterday.  .
Krikey ...another one followed me home  20230610
Krikey ...another one followed me home  20230611
the fuel rail was horrid , with the injectors stuck in the head , glued in by the leaking fuel ,  took a while but got them back into shape , and installed new lines throughout .
Krikey ...another one followed me home  20230418
Krikey ...another one followed me home  20230419
and after a bit of work
Krikey ...another one followed me home  20230420
Krikey ...another one followed me home  20230421
Krikey ...another one followed me home  20230512
dissasembly for leaks
as usual i pulled the driveline , gearbox etc  to get at a pronounced leak all across the rear end
the output shaft seal was kacktus , also finding the alternator seal was weeping badly, including the output seal from the gearbox
Krikey ...another one followed me home  20230422
Krikey ...another one followed me home  20230423
Krikey ...another one followed me home  20230424
now cleaned up
Krikey ...another one followed me home  20230425
did the alternator and starter whilst in there
Krikey ...another one followed me home  20230426
also cleaned up the gearbox , but pulled the front cover off to observe the bearings , lucky i did ...
also found out recently that there was an issue with gearchanges , so bearings and selector drum , forks to be worked on , but progressing
Krikey ...another one followed me home  20230427
cleaned up the front end
including servicing the calipers, cleaning lines , and resurfacing the forks ,  after removing a big bucket headlamp .
Krikey ...another one followed me home  20230514
Krikey ...another one followed me home  20230515
Krikey ...another one followed me home  20230516
refurbished the triple tree , removing short RS bars and installing some rusty but now repainted longer versions , adding 30mm risers to the mix
Krikey ...another one followed me home  20230428
thought about the big bucket headlamp already fitted as a naked thing .....but thought to put out a call for anyone with an old rs fairing or something to fill that void . that still maintained a "k"  distinctive "look " thinking "c" cowl or what-ever .
unbelievably a local (steve ) turned up more or less within a day of so , with a damaged but reasonable looking rs fairing ....   what ?
swapped him a longer rear shock that would fit his paralever rear end on his hybrid k1100 - 100
also luckily a mate paul "brickman" was passing with a couple of mirror pods he had on hand ....unbelievable... swaped him a couple of sidecovers to suit a k75 local to him
lots of fibreglass repairs ensued , with surface filling and repaint going on .
Krikey ...another one followed me home  20230517
Krikey ...another one followed me home  20230518
Krikey ...another one followed me home  20230519
 first iteration
Krikey ...another one followed me home  20230520
second version
Krikey ...another one followed me home  20230612
Krikey ...another one followed me home  20230613
Krikey ...another one followed me home  20230614
doesnt look too bad near the end , still lots of work to go on there to finish it off , plastics to go in ,with under scoop and additional lamps to come , and of corse pockets where the vents usually are ......lol
fishboy316
fishboy316
Progressing very nicely Charlie.
I sit in awe of your patience & skill.  Wink
Yet another worthy K being resurrected. Goodonya!
How we spend our days is, of course, how we spend our lives. - Annie Dillard, author - born 30 Apr 1945
thanks for the encouragement guys , makes taking the time to post progress pics etc , much more worthwhile.
cheers to you both for taking the time to say something
Krikey ...another one followed me home  112350
some frame work
the bike had been sitting in a shed close to the seaside , with flooding reaching the floor to a low level , i guess during the lismore floods , which destroyed my mothers house contents up in lismore itself  some year and a bit ago .
verry sad to attend and toss years of collected furniture books .....everything in the house .
so decided to remove things off the frame to clean up mainly surface rust etc from the little bumps and scratches that occur over the years .
 a sample of what i uncounted all the usual places across the frame
 Krikey ...another one followed me home  20230429
now rust converted after cleaning off the scale , and primed and painted , much better
Krikey ...another one followed me home  20230430
whilst reassembling thought to do a little bling to the rear cowl , inspired by a pic i saw of a k1100 rs , gloss black with silver highlights  , so i guess that translates to the scheme on the front main fairing after this ...
Krikey ...another one followed me home  20230431
the seat was a comfort seat , typical of an rt setup , was ripped , so returned a standard bench seat , in much better condition to the platform , until i can recover the comfort seat sometime in the future .
Krikey ...another one followed me home  20230432
then onto the footplates
just a brighten up of the metalwork
a rework of the rear master cylinder with a new piston and seals  etc
replacing those rusty pivot pins with stainless bolts - nuts
Krikey ...another one followed me home  20230433
Krikey ...another one followed me home  20230434
Krikey ...another one followed me home  20230435
Krikey ...another one followed me home  20230436
Krikey ...another one followed me home  20230437
That's burning the midnight oil, Chaz, but in a productive way. I can think of no better way to pass the darker months up in them thar chilly winter hills.
I'm inspired to light a fire beneath my own feet to finish up the black & silver '96 K1100RS in my garage taking up lift space. The distraction is the state map is spread out on the kitchen table and there are so many good roads. Once again, brilliant job with this motorbike.
RS Rider
RS Rider
WOW! A labour of love for sure. That's looking amazing.
Two Wheels Better wrote:That's burning the midnight oil, Chaz, but in a productive way. I can think of no better way to pass the darker months up in them thar chilly winter hills.
yes , been a bit chilly and dark up here
about -3 c overnights for the last month or so
get out and about Dazza , enjoy those years of solid commitment with the freedom you seem to enjoy and share in here
thanks RS RIDER ..... appreciated
perhaps  a cleanup of those pipes are in order
before
Krikey ...another one followed me home  20230521
Krikey ...another one followed me home  20230438
and after
Krikey ...another one followed me home  20230522
with a touch of something as a sample to continue the theme
Krikey ...another one followed me home  20230523
Lucky you don't have much spare time Charlie. At it again and another K will live...well done.
Cheers Stan
To quote a line from "Jaws" you're gunna need a bigger boat  shed.
Verry likely Martin......lol
Cheers mate
17Back to top Go down   Krikey ...another one followed me home  Empty Nice work Sun Jun 04, 2023 10:04 am
caveman
caveman
I can’t decided if I envy your skill or passion, you have it all.
Thanks for sharing.
hi CAVEMAN
skill, passion ?,
maybe passion , but more likely ocd and madness .....giggles
thanks for the comment... appreciated
Edited: the forum got its knickers in a twist and entered the post in the wrong place.
so moving along again
rebuilt the gearbox
Krikey ...another one followed me home  20230812
and installed the fairing inners , including instruments
Krikey ...another one followed me home  20230813
and actually got both wheels back on the ground ...well its a push around untill i get a battery for it ,,,,and some paint on the tank
but still way too cold for that with -4c temps over night ....most of the fairing paintwork allowed me to take it inside for curing
Krikey ...another one followed me home  20230814
Krikey ...another one followed me home  20230815
firstle
firstle
very nice and well worth the effort (not for profit) you will end up with a good useable bike , unlike the one i just finished , 1936 350 panther , cost a fortune and is not very useable being very slow  Sad
JGT
JGT
Persevere firstle. Just got a 1949 B31 on the road and love it. No not as quick as my K75 but great fun.
1992 K75
firstle
firstle
not given up , yet , working on a 1927 triumph now , i am starting to think these are a poor investment and maybe property would be better but not as much fun , the interest in old bikes is starting to wain as we all get older and no new blood interest , this hit home with this years banbury , limited to 500 every year and has been hitting 500 since i can remember , this year @ 275 , even with Henery cole (im not a fan) . the venue is crap and expensive , its lost its way and interest imo . i have a BSA now 1924 round tank nice bike but rare i ride it . enjoy the B31
Please!  Post photos of these grand old beasts.
Older bikes seem to be extinct around these parts(Western New York State).  There was an old guy who had a shop back in the 40's 50's and 60's who bought up literally every old bike for miles around for parting out.  Some of his bikes went back to before WWI.
He had a big warehouse with thousands of bikes in it when it caught fire(many still had fuel in the tank) back in the early 80's.  Every bike was lost.
firstle
firstle
i will try and sort this out but this site and pics are not that straight forwards ? , not sure why .
here is a link to the panther i just finished re restoring , it belonged to my farther , after the 1st restoration in 1986/7 , and after this feature by Bob Curry , he pushed it into a shed and went onto another project , @ 30 years latter i dragged it out with other bikes , the roof had fallen in and they are all in a very poor state (i have my work cut out) its a real shame but thats how it goes and i think most are saveable if i live to finish them .
The Classic MotorCycle Magazine August 1987 - BSA -NORTON-TRIUMPH | eBay
JGT
JGT
Krikey ...another one followed me home  S-l16015
I get the impression that some people prefer to renovate than ride.  This had a full mechanical restoration including the bizarre paint job and then along with approx. 15 other bikes were left stored in a damp lockup for 12 years until his death. Just needed a stuck exhaust valve freeing off and the magneto reconditioned as the damp had wrecked it.
This is how it looked after awakening from its slumber. Will tackle the paint work this winter.
1992 K75
Thanks for posting the photo.  Love those old machines.
firstle
firstle
just an update ... finally
been pretty busy with bits and pieces of late
got a battery finally
so have changed oils and cranked the new oils through the engine , plugs removed so as to flush and preload new oil in the important places before attempting a start ...pretty soon.
also have investigated paints and what would likely do the job for the tank .
finally bit the bullet and purchased some 2k paint in a rattle can (the type that has a reservoir underneath that mixes the hardener to the mix at point of activation )
i can tell you i was a bit concerned as to what to expect with this kind of paint , and finish .
well away we go
the paint as it arrived
Krikey ...another one followed me home  20231216
prepared the tank with a good primer and a rub back
Krikey ...another one followed me home  20231210
then into the wood shed for the paint job .
was able to get at least 2 coats underneath and 3 to 4 coats on the top
looks ok but a lot of dry overspray around .
Krikey ...another one followed me home  20231211
then some thing i hadnt done before , in as much as cutting back a (for me  a costly paint) with wet and dry (1200 grit )
which kinda turned out not too bad
then onto cutting compound polish
Krikey ...another one followed me home  20231212
and finally some finishing polish ..... man was i surprised when the paint got that sheen happening , that i was hoping for .
doesnt look too bad for a first attempt with this kind of paint eh ?
Krikey ...another one followed me home  20231213
Krikey ...another one followed me home  20231214
also revised the heatshield paintwork
Krikey ...another one followed me home  20231215
Krikey ...another one followed me home  20231217
a bit k1 ish theme perhaps ?
so to repopulate the tank internals , with repaired fuel sender , new fuel filter and pump in the coming days
and then hopefully a start ....????
Looking great Charlie, a couple of the K Kronies have had success with 2k rattle cans.
Merry Christmas.
That's some solid progress, Charlie. It's good to see another K going in your desired direction over the other often sad option.
Nice one Charlie. That 2K stuff is as hard as nails and will take some quite serious abuse from wet'n'dry. If you really want to fall into the finish, rub back with 1000/1200 grit, then take two pieces of the wet'n'dry and run them against each other for a couple of seconds, effectively making them into 2000/2400 grit. Now, if you want to get really serious, do a very light rub back between each coat of laquer.
There is a severe downside to the rattlecan 2K. If you put too much on for a single coat (define "too much" - I know!), it may feel dry but it actually never goes off. When you add a coat on top, it reactivates the heavy layer and turns it semi-liquid again but it still feels hard. The first time you get a petrol spillage on the tank it will all just wash off. Light coats only and leave each coat to go hard (not just the recoat time) before the next.
I miss my HVLP setup... Sad
[Edit] Didn't .75 and I have a discussion about this a while ago? Can't remember the thread - it was probably about something completely unrelated in a totally derailed discussion as usual.
Charlie, that is a first rate paint job!  If you have any of that 2K clear coat left in the can, you can keep it usable for up to two, maybe three weeks by keeping it in the freezer and thawing it out later.  Just make sure you clear the spray head before you put it away.
That is going to be another really nice Brick!  As usual your attention to detail is amazing.  It is always fun to follow one of your projects.
oh ?!!
just thought to share a radiator mod that is in progress , but getting there
as the lower rs fairings evade me at the moment
thought to do something similar to gertys naked look around the radiator , but far less erm... silver this time
started off making the wings for the outer radiator , to concentrate - direct airflow
just a mockup , then real metal , 0.8 aluminum
Krikey ...another one followed me home  20231110
Krikey ...another one followed me home  20231111
then a lower erm splitter , all in black and stainless screws
Krikey ...another one followed me home  20231219
Krikey ...another one followed me home  20231220
Krikey ...another one followed me home  20231218
next to mount standoffs to the radiator external studs and more
looks ok so far ?'
Looks good to me.
Very nice!
well ...it actually runs
however its missing and rattling like crazy , i expect that will disappear as it runs some more
and those valves that have been open for however many years settle back into their seats and i get some even compression across all cylinders
i threw in a bit of flash lube (upper cylinder lubricant ) to help it on its way ...
fingers crossed .....
nearing completion with a radiator mod in place ,
still to add hi gloss side covers
tank done with 2k
and to make some tank badges ....  and maybe some bling in the paint work ......
but, getting there !!!!
thoughts ?
Krikey ...another one followed me home  20231223
Krikey ...another one followed me home  20231224
Krikey ...another one followed me home  20231225
Krikey ...another one followed me home  20231226
Krikey ...another one followed me home  20231227
How did you do the r/h panel that wraps around the thermostat? The traditional way with a dolly or some Charlie magic?
Brute ignorance , a hunk of 35mm steel bar stock and a 3 pound lump hammer and a piece of wood ....
What you expected ?
Lol
Krikey ...another one followed me home  Charli10
I've got a helmet for you, Charlie!
Laughing
lol! Krikey ...another one followed me home  723598 lol!
Since I stopped riding funeral escorts & parades & got rid of the R1200RT-P the Nolan N105 doesn't get much use. Too plasticky and flexible, but good for its intended purpose as a "po-po" helmet.
charlie99 wrote:Brute ignorance , a hunk of 35mm steel bar stock and a 3 pound lump hammer and a piece of wood ....
What you expected ?
Lol
Just about Very Happy
At least its running nowKrikey ...another one followed me home  20231228Krikey ...another one followed me home  20231229
I really like how you painted the fairing.
Krikey ...another one followed me home  212902 Krikey ...another one followed me home  212902
charlie99 wrote:At least its running nowKrikey ...another one followed me home  20231228
From here it surely looks like much more than just a runner! Another fine example, Chazza.
Before long you'll have a verified mob of mighty Ks.
Laughing
