1Back to top Go down   Changing speedo from MPH to KPH Empty Changing speedo from MPH to KPH Tue Feb 09, 2016 7:48 am
coopz
coopz
Hi All, some years back I bought my K100 it was a USA import with MPH speedo. Is there a sticker or such like with KPH that I can place over the original. Unless I can buy a very cheap replacement speedo many thanks Coopz.
1985 K100 RS
2Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Tue Feb 09, 2016 8:03 am
I've toyed with that idea too Coopz. We have the weird situation in Ireland where we went metric years ago but are seen by most manufacturers as Right hand drive/Uk spec (Yes you heard me!  Very Happy ). Despite changing our roadsigns and speed limits to KPH our government still sees fit to let our motor industry supply MPH speedo's and Odo's.
It seems to me the most expedient thing to do is to change the whole clock unit to a KPH one. If you get an old Police spec one you get the calibration in 2KPH increments too.
Changing speedo from MPH to KPH Ir-log1188....May contain nuts!Changing speedo from MPH to KPH Ir-log11
K75RTP - 1994
3Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Tue Feb 09, 2016 8:13 am
coopz wrote:Hi All, some years back I bought my K100 it was a USA import with MPH speedo. Is there a sticker or such like with KPH that I can place over the original. Unless I can buy a very cheap replacement speedo many thanks Coopz.
I have a few old units here that have been ratted for bits I will have a look and see if there is a good KPH face and you can get the gears to convert the odo to KM. Ainsjac was saying he got some gears from Jaycar but I dont know which ones.
4Back to top Go down   Changing speedo from MPH to KPH Empty MPH speedo to KPH Tue Feb 09, 2016 8:20 am
coopz
coopz
Thanks for that, any advice most welcome. Also can you tell me if a K1100 LT 1993 speedo unit would fit a K100 they look almost identical reason being is there's one for sale. Coopz
1985 K100 RS
5Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Tue Feb 09, 2016 8:33 am
Chocolate
Chocolate
Hello!
The Speedo from the K1100 will have round connections, if you have round connections on you bike it will fit!
From when is you K 100?
If you get a "new" Speedo make sure you get the correct one.
There are round connection and squared connection.
I think they changed from round to squared 1990.
Before 1988 the gasoline display has changed, because the mechanic in the tank has changed.
Befor that time there is no ABS light/possibility!
Changing speedo from MPH to KPH <a href=Changing speedo from MPH to KPH Image41" />
Changing speedo from MPH to KPH <a href=Changing speedo from MPH to KPH Image42" />
6Back to top Go down   Changing speedo from MPH to KPH Empty MPH to KPH Tue Feb 09, 2016 8:28 pm
coopz
coopz
Thanks for the info pretty sure its square plug. I'll hang on to see if Ric has something, although Ive had nothing to do with the internals of a Speedo will be interesting. Cheers.
1985 K100 RS
7Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Tue Feb 09, 2016 9:14 pm
This is a very interesting subject. What is different?
The speedo sensor or just the marking on the speedo.
I just went to the workshop and took 2 different speedos expecting that the only difference would be on the marking of the face. Wrong unless they are from 2 different types of bike (One goes up to 240km and the other to 260km). They maybe RT and RS.
I don't know if that exist, but does anybody has a picture of a speedo in miles going to 150mi/h?(This would be the equivalent of 240kms)
For the distance traveled, The gears would definitively be different, but for the speed it could only be the markings on the face.
Changing speedo from MPH to KPH 20160210
Changing speedo from MPH to KPH Frog15Changing speedo from MPH to KPH Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
8Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Tue Feb 09, 2016 10:32 pm
Looks like the markings are at different positions. I have a speedo from a 1990 model that I got from US for spares and it is the same as that one.
Coops the only dial I have is very badly buckled from heat and the needle wont go past the warped section but I do have a complete unit that came from a 86 that I wrecked about a year ago. It's fairly good but the clock has bled out. It has the square pins but only one fuel light. If you are interested in buying send a PM and we can work something out.
The round and square pins aren't compatible, the plugs don't even interchange.
9Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Tue Feb 09, 2016 11:43 pm
The small main drive gear....all the others are clustered together.... can be bought from Jaycar in a packet with other gears that may not be of use..cost about $6...cheaper than $25 plus postage.
10Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Feb 10, 2016 4:44 am
If the faceplates are interchangeable between the mph & kmh speedos is there enough adjustment in the speedo mechanism to calibrate it to a kmh faceplate using the Karamba software? You would probably be able to pick up a faceplate from someone off the forum who has a stash of K bits lying around.
Any thoughts on this approach from the wise ones on here?
I expect the odometer would need a change of gears as the other guys have mentioned.
11Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Feb 10, 2016 6:21 am
Gaz80 wrote:If the faceplates are interchangeable between the mph & kmh speedos is there enough adjustment in the speedo mechanism to calibrate it to a kmh faceplate using the Karamba software?
You have a very good point Gaz. I remember when a couple of year ago I was playing with Karamba, that the small variable resistor permit quite a wide range of setup.
12Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Feb 10, 2016 6:46 am
I heard 20% on the trim pot but does it change just the speed reading or both odo and speedo.
13Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Feb 10, 2016 6:52 am
The marked speed at the vertical is 80Mi and 100km
80Mi = 128.748km
If you reduce 128.748 by 20%, the speed will be 103km. Close enough?
14Back to top Go down   Changing speedo from MPH to KPH Empty MPH tp KPH Wed Feb 10, 2016 7:26 am
coopz
coopz
It all sounds interesting think I might hang on a bit not in a hurry and see if I can work through this thanks Ric for looking.
1985 K100 RS
15Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Feb 10, 2016 8:15 am
I think that was 20% over the whole range not +- 20% so it may or may not work.
One option is a Speedo healer
http://www.healtech-electronics.com/products/sh/
Many of the Kawasaki guys use them to remove the speed limiter for track days.
16Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Feb 10, 2016 5:35 pm
Rick, I remember in the Karamba discussion that Duck had noted here in post 91 that the speedo sensor signal was split and fed separately to the speedo and the odometer, so if the speedo was adjusted it would not change the odometer. I guess that is where a change of gears is required.
17Back to top Go down   Changing speedo from MPH to KPH Empty Re: Changing speedo from MPH to KPH Wed Oct 25, 2023 2:14 pm
Tranberg
Tranberg
I've only done about 250 km's on my K75 RT and, being used to a digital speedometer accurately calibrated with a SpeedoHealer,  I'm already sick and tired of only using half of the speedometer scale, although it uses 15% more than it would, if it wasn't lying like a politician.
So I'm contemplating getting an MPH Speedometer and setting the Speedo Healer to deduct 12-15% (whatever it takes) and further divide by 1.6
That way, I will get an accurate speedometer, with a useful scale in everyday traffic.
Has anybody done that before?
