1Back to top Go down   85 onwards new fuel level sensors Empty 85 onwards new fuel level sensors Fri Feb 09, 2024 5:54 pm
Better sit down before you check the price:
https://www.motorworks.co.uk/fuel-level-sensor-fua59565-3.html
2Back to top Go down   85 onwards new fuel level sensors Empty Re: 85 onwards new fuel level sensors Fri Feb 09, 2024 11:21 pm
Jordan53
Jordan53
Is it the case that the fuel tank should never be allowed to run empty, because that could damage the fuel pump?
I suppose fuel has to be delivered at some pressure, higher than gravity can provide?
1989 K100 RS
VIN: xxx0149621
3Back to top Go down   85 onwards new fuel level sensors Empty Re: 85 onwards new fuel level sensors Sat Feb 10, 2024 12:00 am
If tanks sit for extended periods, as in years, and the gas in the tank has ethanol in it then the ethanol absorbs humidity. When you get enough water in the gas it will rust and destroy the fuel level sender.
It doesn't matter if you run out of fuel as far as the fuel pump is concerned.
4Back to top Go down   85 onwards new fuel level sensors Empty Re: 85 onwards new fuel level sensors Sat Feb 10, 2024 12:04 am
EME sells them for the low price of only $269. affraid
https://www.euromotoelectrics.com/product-p/flf-565edl.htm
Interesting price, Duck. It would indicate that the units are made in the UK and then shipped to EuroMoto because that's pretty much the same price. If the shipping direction was the other way about I'd expect to see a £270 price tag here, courtesy of the usual dollar-sterling straight conversion.
I heard from a reliable source that Motorworks are sourcing them from here
Fuel level float NEW 62161459565 – KpartsHolland
85 onwards new fuel level sensors Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 60K Km     ;BMW;  K1100RS Black 1996       ;BMW; K1 Blue 1990 25K Miles
They all look the same from Motorworks, EME & K Holland. If I had to guess I'd say they're all made in China or Vietnam.
The most noticeable difference seems to be the plastic connector at the base:
85 onwards new fuel level sensors D3Fk8KJ
You're probably right about China. Prices are all pretty much the same so a best guess is that whoever is distributing them, it's a single-source manufacturer.
10Back to top Go down   85 onwards new fuel level sensors Empty Re: 85 onwards new fuel level sensors Sat Feb 10, 2024 5:37 pm
Cheaper though from www.kpartsholland.com
