K1100 wireloom questions Mon Apr 22, 2024 7:15 am
SunnyPerth
![SunnyPerth](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
![K1100 wireloom questions Img_6810](https://i.servimg.com/u/f36/20/47/60/78/img_6810.jpg)
![K1100 wireloom questions Img_6811](https://i.servimg.com/u/f36/20/47/60/78/img_6811.jpg)
![K1100 wireloom questions Img_6710](https://i.servimg.com/u/f36/20/47/60/78/img_6710.jpg)
Making steadily progress with the ground up resto of my 93 K1100lt - see first image attached. Now ready to start putting back in the wire loom(s)
Have two questions there
1) while cleaning / checking the ‘lower’ part of the loom, I noticed a few of what looks like on purpose made pin holes (drain holes ?) in the wire sleeve going to the ignition control unit. Looks the 4 holes are in there with an offset from each other and potentially on the lowest point of the loom.
Is that correct, are they there intentionally?
(Or should I check if this is heat / age related and check the wires within)
2) besides the check/upgrade of the earth cables and putting in extra relay for headlight, should I do any other mods to electric system ?
Cheers, Y
