1Back to top Go down   Oil drip from pushrod area. Empty Oil drip from pushrod area. Fri Oct 07, 2011 11:07 am
BooG
BooG
Hi. Have noticed a small drip of oil from the rubber boot where the clutch pushrod is located. What's that all about then?
2Back to top Go down   Oil drip from pushrod area. Empty Re: Oil drip from pushrod area. Fri Oct 07, 2011 1:01 pm
club_c
club_c
Boot is torn, probably at the top, needs a replacement.
1988 K100RS SE VIN 01477554
3Back to top Go down   Oil drip from pushrod area. Empty Re: Oil drip from pushrod area. Fri Oct 07, 2011 1:51 pm
It also could be that it`s leaking between the boot and actuator arm.
If so, remove and clean boot and the contact area at the arm (use solvent to get all traces of oil removed, I did use acetone, sparingly).
Apply some gasket sealant in this area (I`ve used Permatex black RTV) put together and let it cure over night.
(I did this work with both arm and boot removed from the bike, not necessery but easier to get the parts clean).
4Back to top Go down   Oil drip from pushrod area. Empty Re: Oil drip from pushrod area. Fri Oct 07, 2011 2:15 pm
BooG
BooG
Ta!!
5Back to top Go down   Oil drip from pushrod area. Empty Re: Oil drip from pushrod area. Sat Oct 08, 2011 1:48 am
geordnz
geordnz
I've got the same problem, it's so slight that i've just left it. It keeps the original centre stand coated. Lol
