1 Headlights won't come on, but High Beam indicator will! Sat Dec 17, 2011 3:43 pm
wavery
Hi. I just stumbled upon this space today. It's great.
I recently bought an older (1987) K100 RS. First bike in over 20 years. I'm learning to work on it...fluids, spark plugs and the like, but I'm no mechanic. With the darker days upon us, I've discovered the headlight does not always come on. I can tell it's not on now because the High Beam indicator will be lit if the headlight is off. Then other times the headlight will come on, so it's not the bulb. I'm guessing it's a problem with the switch? I've read through some of the posts related to headlights and switches, and from what I can tell, replacing the switch doesn't seem like the sort of job a neophyte should take on. Or am I seeing a mountain where there' s a molehill. Any thoughts? Thanks!
