1 starter problems + electrical Mon Feb 20, 2012 3:25 pm
rikabee
I just purchased a k100rt which was not running. I can not get the starter to energize through the start button.I have jumped out the starter with the battery and will turn over ok. I purchased a new relay but still refuses to start. I checked the voltage off the ignition switch and get 11.5 volts even though the battery shows 12.5. When I use the starter button it is only 8.5 volts.I can not seem to find why I have so much a voltage drop at the button. I had the switch apart and everything seems to be ok. I have done the trouble shooting from crazy frog. the values I get from the ignition box show the box is bad. I am not 100% sure. I do not want to replace parts that could be good as this could be expensive. The last owner had many electrical problems with this bike and that is why he sold it. Any help would be wonderful as I would like to get it running. Steve
