1 New sound coming from timing chain area Tue Dec 15, 2009 4:07 am
scottiesharpe
I noticed a new sounds, ticking, clinking coming from the timing chain area when I am stopped at a light. The sound goes away above idle.
On my M88/3 powered M5, I destroyed an engine when the timing chain guides became brittle after 18 years and broke off. The fragments locked the cam chain and stopped the cams, destroying the entire upper engine.
Expensive lesson to replace timing chain guides on BMW motors after so many years.... However, I imagine the material used for the guides (and the technology of the cam tensioner and geometry of the gears and so forth) is probably very similar on the K100 as it is on my M5.
I am going to pull the front engine case (can it be easily done?) and have a look to see what is happening in there.
Has anyone every had to replace any timing chain components?
Scottie Sharpe
