1Back to top Go down   ABS switch -- what does it do? Empty ABS switch -- what does it do? Tue Aug 14, 2012 6:55 pm
Switzerr
Switzerr
Hello All,
what does the ABS switch on my 91 K100 RS do? I've tried a search, but I mustn't be using the right search terms.
Rob
2Back to top Go down   ABS switch -- what does it do? Empty Re: ABS switch -- what does it do? Tue Aug 14, 2012 8:47 pm
Hi switzerr. The ABS switch is almost decorative but its only purpose is to turn off the flashinh lights that come on when a fault occurs in the ABS system. Apparently it is to prevent the rider being distracted by these flashing lights. Actually it does have a second purpose and that is in helping to reset the ABS computer to its default parameters but there are other things involved there.
3Back to top Go down   ABS switch -- what does it do? Empty Re: ABS switch -- what does it do? Wed Aug 15, 2012 12:20 am
Switzerr wrote:Hello All,
Rob
Try this article on:
http://www.largiader.com/abs/absfault.html
~Mac McCleary
