1Back to top Go down   k100 front brake light switch Empty k100 front brake light switch Tue Aug 26, 2014 3:13 pm
audibob
audibob
Hi guys, anyone managed to repair the front brake light switch on a K100? Lubricated mine a few times to get it working but is now dead. The soldered wiring is intact, so presume plunger contact is not working.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   k100 front brake light switch Empty Re: k100 front brake light switch Tue Aug 26, 2014 3:29 pm
you might be able to take the switch out so that you could orient it so that you could get some wd40 in there and stay there whilst activating the plunger ,,,this might clean up the contacts a bit easier ?  afterwards clean the wd 40 out of the mechanism with some electronic cleaner carbi cleaner so that it doesn't coagulate into a non conductive goo ...your trying to flush out all the crap that loosens .
but its not an uncommon thing that they do fail ...usually cause they don't get regular servicing ....till they become intermittent
3Back to top Go down   k100 front brake light switch Empty Re: k100 front brake light switch Tue Aug 26, 2014 3:45 pm
If you have a working choke light, then swap the switch on the end of the TB rail with the brake switch.  Not having a working choke light is less impactive than having a non-working brake light.
4Back to top Go down   k100 front brake light switch Empty k100 front brake light switch Tue Aug 26, 2014 5:07 pm
audibob
audibob
Thanks guys,
I guess i would like to keep my choke switch as it works, just wiggled the wires behind the brake switch, and hey presto it came on for a second then went out, so probably a break in the wire. At least the plunger works, so a new feed wire coming up. just have to find the connector hidden inside  the fairing somewhere.
Nice to have a cheap fix  for once.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
5Back to top Go down   k100 front brake light switch Empty Re: k100 front brake light switch Tue Aug 26, 2014 8:58 pm
The connector is under the tank
6Back to top Go down   k100 front brake light switch Empty Brake light switch Tue Aug 26, 2014 9:19 pm
gladstone sa old fart
Same switch has been used since 1969 on all /5  /6  /7 models, front brake & clutch lever switches
PJ
http://pjingladstonesa.blogspot.com
7Back to top Go down   k100 front brake light switch Empty Re: k100 front brake light switch Wed Aug 27, 2014 2:09 am
Well, live and learn!
Good info PJ.
