1Back to top Go down   Fitting Bigger Tyres Empty Fitting Bigger Tyres Thu Feb 07, 2013 11:08 am
twincarb
twincarb
I am currently running 130/90 17 on My rear.... and a 100/90 18 on the front....
It's time to get a larger rear going up to the 140/80 17 my question is can I keep the front as stock as it's got more meat on it than a Rib Eye Steak so don't want to bin it yet....
forgot to mention I am using BT45's at the moment...
Yamaha Thundercat
Fitting Bigger Tyres 169042 Fitting Bigger Tyres 169034
2Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Thu Feb 07, 2013 12:56 pm
i have tried both the 130 and the 140 options twincarb ....same brand of tyre to the front and both were great i think im doing better with the 140 this time around, but still only about 7000 ks up yet
looks to me that i got a long way to go before it gets down to thinking about a change
btw i have the 110 on the front
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OFitting Bigger Tyres Au-log10
3Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Thu Feb 07, 2013 1:24 pm
japuentes
japuentes
Hi there, I´ve been running 110/80 at front during the last 12000Km, I think you can not fit nothing wider there, at least on mine. At rear I had run 140/80 and now 150/70, the last being the limit for both wide clearances and rim size.
Best regards
JAP
Fitting Bigger Tyres 2854237993 1988 K100RS SE/ABS
4Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Thu Feb 07, 2013 6:31 pm
Themason
Themason
110/80-18 front and 140/80-17 rear works fine on the stock wheels. A shop once made an error and put a 120/7ZR18 front tire on my bike instead of the 110/80ZR-18 I thought I was buying and it fit fine. The difference in steering feel made me look at the tire sidewall and that is when I noticed the size was wrong, but it didn't rub anything. The shop was apologetic and replaced the tire with the size I wanted. If you are ever in a bind and need a tire right now, it is something to keep in mind.
1986 R-80G/S w/1000 cc engine
5Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 2:56 am
nino
Hi, did anyone try wider tyres, 120 front, 160 rear? Is it possible on rear without modifications (spacers)?
6Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 4:54 pm
Themason
Themason
Nino, like I said above, a tire shop once put a 120/70ZR18 on the front and nothing rubbed. I made the shop replace it because I noticed the difference in steering feel, but it does fit.
You can put a 4.5X18 rear wheel and 160/60ZR18 tire on the back of an early K and it will fit except for the stock K100 muffler. If you use a muffler from a 16 valve bike or aftermarket exhaust the collector will clear the tire adequately where the stock collector will rub. You cannot put a 160 tire on the stock, narrow rear wheel.
7Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 5:14 pm
nino
Tnx Themason, what about rear tyre of big enduros like GS 1200 150/70 17 on my old narrow rim?
8Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Fri Feb 08, 2013 7:05 pm
@nino wrote:Tnx Themason, what about rear tyre of big enduros like GS 1200 150/70 17 on my old narrow rim?
A five spoke wheel is 2.75x17 and therefore too small for a 150mm tyre. The proper width wheel would be 4" wide for that size. Maximum tyre width for your wheel is 140mm in an 80 series.
1970 R60/5, OZ '77 R75/7-R100, '85 K100'87 K75C, OZ '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, '06 K1200R, '07 K1200R, '09 K1300GT & 2013 R1200RT-Polizei  - Beemers owned still or sold.
~We all believe what we want to believe in - Rob Dickinson
9Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Mon Feb 11, 2013 1:55 pm
Themason
Themason
Dual sport tires on a K bike? That sound you just heard was my rectum slamming shut.
10Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Mon Feb 11, 2013 2:34 pm
twincarb
twincarb
Dual compound tyres would be the ideal!
Yamaha Thundercat
11Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Tue Feb 12, 2013 11:44 am
Themason
Themason
[quote="twincarb"]Dual compound tyres would be the ideal![/quote]
Lots of those from Dunlop and Avon.
12Back to top Go down   Fitting Bigger Tyres Empty Re: Fitting Bigger Tyres Tue Feb 12, 2013 5:39 pm
twincarb
twincarb
i guess in the 140 tyre range? my local place says they can't get any in the 130's...
Yamaha Thundercat
